MobileCustoms
You can twist perceptions, reality won't budge
3.23 x .78 comes out to 2.522.71 I think with 3.23 and GV
Ok...3.23 x .78 comes out to 2.52
Thanks Tim my memory is short.2.71 I think with 3.23 and GV
I know it was worth the effort to install in my 66. Makes a differenceThanks Tim my memory is short.![]()
It doses and I deleted the computer on mine because it went bad, so now I have to make sure I take it out of overdrive before I go in reverse.I know it was worth the effort to install in my 66. Makes a difference
Yes you do. I think it has a sprang in it. Reverse would be a no noIt doses and I deleted the computer on mine because it went bad, so now I have to make sure I take it out of overdrive before I go in reverse.
What year is your car?It doses and I deleted the computer on mine because it went bad, so now I have to make sure I take it out of overdrive before I go in reverse.
73 Tim.What year is your car?
For the what it’s worth column I have witnessed with my own beady eyes and drove in and alongside a couple of folks running the OD setup including @Frodee They all liked the result. Only gripe is the reverse protocol. I am about to pull out my spooled 433s and am giving serious thought to doing the same.3.23 x .78 comes out to 2.52
Hopping you keep that cool looking Cuda. I still have a picture of it.For the what it’s worth column I have witnessed with my own beady eyes and drove in and alongside a couple of folks running the OD setup including @Frodee They all liked the result. Only gripe is the reverse protocol. I am about to pull out my spooled 433s and am giving serious thought to doing the same.
Thanks Fred, those pix sure bring back some memories! The Cuda is just perfect in my eyes but the toggle switch dash and removable steering wheel are a turn off to a lot of folks. By same token that’s why their key don’t fit!Hopping you keep that cool looking Cuda. I still have a picture of it.
Well, if their key doesn't fit it's because their key was designed for a minivan.Thanks Fred, those pix sure bring back some memories! The Cuda is just perfect in my eyes but the toggle switch dash and removable steering wheel are a turn off to a lot of folks. By same token that’s why their key don’t fit!
32* here and snowing and a blowing. Think I need to move a bit farther South.Good Afternoon All! Snow what??? It can't decide here, 54 and showery
Yeah, Junes right around the corner, crazy!32* here and snowing and a blowing. Think I need to move a bit farther South.![]()
Well, crap Fred...32* here and snowing and a blowing. Think I need to move a bit farther South.![]()
Think I might go build a snowman or just a warm blanket and hot chocolate.Well, crap Fred...
Sweating my chackas off having just finished 5 hours of yard work
Keep your head up!!So, do the Ragnars come out angry tonight after the home opener punch in the mouth?
