Yes it dose.Mine is all original paint. I’m leaving it. Shiny paint causes stress![]()
About time you took a day off. Great pictures thanks for sharing.Thanks for the Birthday wishes guys!
Was a good day. Didnt get the box on Studebaker though. Wife conspired and made a party. Too many friends i have trust issues with now…
Pains me to hear that Tim.It's fried
Happy Birthday! It looks like it was a great day.Thanks for the Birthday wishes guys!
Good... hope the MOPAR gremlins make some magic
Definitely more options with a manual to make things work in a pinch.Must be a clutch thing on autos and manuals. I had to get my teen aged *** home from work at midnight with no clutch in my 4 spd Ranchero. The pivot on the clutch fork broke.
Have the same Gremlins here.It has to be the PA Gremlins. Been working on my Jeep rear differential putting in a Pinion Bearing. I have had 2 different rear end guys come and tinker and still sounds like I have massive snow tires on going down the road and when you let off the gas there is a whine. Second guy does rear ends and used dial indicators and everything and says it is all within specs. I am wondering if someone sold me a bad bearing. All new bearings and new crush sleeve.
It has to be PA Gremlins
Bands can be adjusted with just dropping the pan. But replacement I think will require removing the unit and pulling the pump.Can that be fixed without dropping the trans?
The Dart on his trailer?Tim’s on his way back to Bowling Green.
Not yet, just left my houseThe Dart on his trailer?
Pinion bearing, and or worn gears or improperly set.It has to be the PA Gremlins. Been working on my Jeep rear differential putting in a Pinion Bearing. I have had 2 different rear end guys come and tinker and still sounds like I have massive snow tires on going down the road and when you let off the gas there is a whine. Second guy does rear ends and used dial indicators and everything and says it is all within specs. I am wondering if someone sold me a bad bearing. All new bearings and new crush sleeve.
Howl in coast/decel I would lean towards pinion depth/gear mesh. Or too much preload on the bearingIt has to be the PA Gremlins. Been working on my Jeep rear differential putting in a Pinion Bearing. I have had 2 different rear end guys come and tinker and still sounds like I have massive snow tires on going down the road and when you let off the gas there is a whine. Second guy does rear ends and used dial indicators and everything and says it is all within specs. I am wondering if someone sold me a bad bearing. All new bearings and new crush sleeve.
Most ring gears and pinions are marked with what the pinion depth should be. I have set up a few ring and pinions in my time. I have a pinion depth gauge that sits in the saddle where the ring gear goes reaches down and measures the pinion depth. This is critical to having a quiet gear set. Obviously after the pinion depth is set then the clearance between the ring gear and the pinion must also be set. But it sounds to me like you are using the same ring and pinion as you had before the bearing noise. If that's the case then maybe the bearing is installed and properly are too tight. Does his have a crush sleeve? A few things to consider.Howl in coast/decel I would lean towards pinion depth/gear mesh. Or too much preload on the bearing
This isn't mine, just replying to what the howl could be. I worked in off highway drive train for 16 years building differentials. Howl on cruise and coast to me sounds like set up is wrong or bearing is tight.Most ring gears and pinions are marked with what the pinion depth should be. I have set up a few ring and pinions in my time. I have a pinion depth gauge that sits in the saddle where the ring gear goes reaches down and measures the pinion depth. This is critical to having a quiet gear set. Obviously after the pinion depth is set then the clearance between the ring gear and the pinion must also be set. But it sounds to me like you are using the same ring and pinion as you had before the bearing noise. If that's the case then maybe the bearing is installed and properly are too tight. Does his have a crush sleeve? A few things to consider.
