zkx14
Duster De-ruster
Go Mike!Thanks. looking forward to a 69.
Make sure you get cabana that is shaded in the afternoon. I go to Vegas all the time. And rent cabana to. Nice way to waste time..It's been a crappy/cold spring so far, 49 degrees out right now so we booked a quick getaway to Las Vegas, leave in 7 days so I checked the weather forecast there, 113 degrees, that outta do it lol! Wife reserved chairs at the pool, may look at a cabana instead
What casino?It's been a crappy/cold spring so far, 49 degrees out right now so we booked a quick getaway to Las Vegas, leave in 7 days so I checked the weather forecast there, 113 degrees, that outta do it lol! Wife reserved chairs at the pool, may look at a cabana instead
@toolmanmikeIf the converter failed it would still send metal shards through the transmission.Would hate to tear Trans apart if it is just a failed converter. I have a magnet in the pan. That will tell a lot I think...fluid still bright red. Does not smell burned..
Thanks . Hey, that looks like fun!Happy Birthday @toolmanmike View attachment 1716263189
He has it on her as well. Western Maryland
And the magnet would show that. Thanks.If the converter failed it would still send metal shards through the transmission.
Then there is this. I asked builder about this he said not to worry about it.
I talked to Stan at length on this. He did install HD spring. And he said it was OK to leave it. Found original receipt. Calling him tomorrow.
Good luck.I talked to Stan at length on this. He did install HD spring. And he said it was OK to leave it. Found original receipt. Calling him tomorrow.
That’s 69 years of earned age my friend. You’ve earned every minute. Happy birthday! Enjoy itThanks. Not looking forward to being 69.
A failed pump or even a failed sprang. But what I would do first is pull the front cover off the trans, check to make damn sure the converted bolts didn’t come loose and run it in park, see if that makes it sound louder or not. When the converter failed on my charger, removing the front cover made it much louder.So how can you tell is issue with Trans. Is the converter? Trans rattling in neutral. Park
Come on. Bolts hitting something won't cause Trans to not move. Think about it.... it's not that for sureA failed pump or even a failed sprang. But what I would do first is pull the front cover off the trans, check to make damn sure the converted bolts didn’t come loose and run it in park, see if that makes it sound louder or not. When the converter failed on my charger, removing the front cover made it much louder.
Then I’d drop the pan before pulling the trans. Check obvious , filter etc. if all that checks out, I’d call that Stan guy and see what his thoughts are
