WhooooshStarter fluid goes in well then explodes!
No silly more like a WHOOOOOOMP!Whoooosh
The ultimate is acetylene if you had a torch. That crap explodes! When young we all had junkers and every now and then someone would break the nipple off the back of a headlight and fill the bulb will acetenyl. Pretty funny blows the grill out of the car! Junkers were like 20 back then. Lots of impromptu demo Derbys in parking lots like 7-11!
Good luck!Brake lines showed up from dr diff... they look sooo short, hope they reach
UGH!Brake lines showed up from dr diff... they look sooo short, hope they reach
The John Deere stuff is the best. 80% EitherStarter fluid goes in well then explodes!
Nope. The 67's have a rubber grommet for the pcv. Last year for the double stovepipes was 66The 66 and 67 covers both have stovepipes. Difference is where the wires to alt run. 66 has a metal guard to block wires from heat on intake. 67 does not
I do and I really like it, makes big batch cooking so much easier. Even heat easy cleanup. You can put a couple of pounds of bacon on at one time! Or depending on burger size as many as will fit. No flame just easy!Hey any one have a portable Blackstone griddle? Thinking of going that way for Carlisle. Old grill was done this year just threw it out
Really. OK. So what year does not have metal guard and stove pipe?Nope. The 67's have a rubber grommet for the pcv. Last year for the double stovepipes was 66
65Really. OK. So what year does not have metal guard and stove pipe?
So I heard you could do it this way, I also heard it was most effective when the electricians have their hands in a high voltage panel, if say perhaps they pissed off the welders? You light torch and set for clean cutting, extinguish flame with your hand not adjusting valves. Point nozzle into big zip lock bag. When full, seal. Then put zip lock in paper grocery bag which then acts as fuse, allowing sapper to place said bag close to electricians. Light paper bag then casually walk away. By the time it goes you are nowhere near the event and I assure you there is no remains. The electricians will absolutely panic and after cleaning out their pants and ensuring none are hurt, they will spend hours looking for ground fault on high voltage. I have absolutely no idea if this works or not but I heard a guy talking about another guy who knew a guy, well you get the picture!
We used to play around with my uncle's torch set to make bombs. He would get so mad when the tank was a lot lower than what he recalled. He knew it was us kids
I'm an idiot Mike. Can you drop the link to the sticky. ? Couldn't find itNope. The 67's have a rubber grommet for the pcv. Last year for the double stovepipes was 66
Ahh the smell of napalm in the morning!
The blue stuff is good for freezing cash in.Know what works well dollar store tidy bowl eats aluminum though.
No, you just can't find it. Charger/Commando valve covers.I'm an idiot Mike. Can you drop the link to the sticky. ? Couldn't find it
I use molasses .Just vinegar actually does a pretty good job. Gotta get the hi % stuff though.
nice cook on those eggs
