But you are a VIP so Priority was the right place for you to beMade it through airport security in about 5 minutes. Accidentally walked through priority boarding…
You work on electronics?Deoxit didn't do the trick on my integrated amp, should pull the board but pretty sure it's just wiped out (pun intended). Sooo, found a whole bunch of parts on fleabay being sold as a group, put in an offer, kinda dangerous cause the volume pot could be in just as bad of shape but there's a lot of parts (basically all the switches and leds the amp has) so think it's worth it anyway if offer accepted. Did the same thing yesterday on parts for a Motorola 8 track, working on the one Wolfie gave me, that guy ghosted me, sheesh! (people are proud of their "not tested" stuff)
Worth the money from prices I've seen.
. SLC2 is in the same area as the Minute Man silos. It's weird, all the security the USAF has out there, AMTRAK runs right through the base
Actually really cheep for that Don Garlits one! The tach itself is worth that have seen those cups themselves sell for 500
I sent those photos to a old customer of mine. They have a repair shop, mostly diesels and turbochargers. They truck and tractor pull and they have put those 4BT Cummins in a lot of vehicles. They were the "go to guys" for the old 5.7 and then the 6.2 and 6.5 GM diesels. Dean was a wizz at rebuilding the Roosa-Master injection pumps. Great family business and always a fun shop to step into.
Bryce said probably 35 mpg or so.
k... i have like 20-23k into my car worth 10k but having to pay $200 for a fire extinguisher is pissing me off soo much... it's weird.. if it was a new carb.. $700? ok.... but this... grrrr
going back to the aluminum slots. cragars will go on the shelf until I replace drums from being worn out or whatever is next. Maybe 5 years from now...........................I suppose you could grind off some of the weight or may be try spacers. I didn't notice much imbalance after I knocked the weights off.
i prefer the slots on that car honestly...going back to the aluminum slots. cragars will go on the shelf until I replace drums from being worn out or whatever is next. Maybe 5 years from now...........................![]()
Was Milan NHRA?Just saw on facebook... Milan (my home track) is grinding and resurfacing the entire track... IHRA isn't messing around there...
NOOOOOOO It will corrode everything !was going to get a element 50 extinguisher but watched reviews and think i will get a 2.5lb dry one and pray for the best...
Was Milan NHRA?
well..the plan is to not catch fireNOOOOOOO It will corrode everything !
well..the plan is to not catch fireall my lines are new... the wiring is only 63 years old.. so it's fine...
