Put that rear one onI went with Hellwig on mine. SDTrucksprings.com had them for $100 cheaper than anywhere else. They were out of stock, but Summit had them and price matched. I ordered them last summer. I think they were $230 eaxh for the front and rear. The front made a huge difference, I haven't installed the rear yet
no more roll over, and it ties it down.
Put that rear one onno more roll over, and it ties it down.
Hellwig #55917 is the “pro touring” front sway bar, it puts the sway bar tabs in a similar spot as the 73+ cars and increases tire clearance. If you’re planning on 17+ rims and anything 245mm or wider for tires in the front you need the #55917.
If you want to have the stock 67-72 sway bar tab locations on the LCA’s, Hellwig #5906 is what you need. It can be used with the factory LCA tabs. But that bar will limit tire width to about 235mm max.
Hotchkis also makes a very nice bar for the 67-72 cars, but it’s more expensive and functionally isn’t much different than the #55917. The Hotchkis bar, like the 55917, will not work with the factory 67-72 LCA tab locations. Which doesn’t matter unless you have LCA’s from a factory sway bar car.
Sanity check. Supposedly this is going to be a street car / driver. At least that is what I tell myself.
So... I have a '68 A-body with a '75 K-frame and QA1 LCAs. I have what I think is an ADDCO '73+ sway bar for the front that I purchased and installed about 25 years ago currently on a shelf. It is yellowish and 1-1/8" solid bar. I have FF 1.12" torsion bars, welded and reinforced K-frame, Borgeson PS, roller bearing idler, and the sector shaft support. I have Spax adjustable shocks. Plan is for 275/35-18 or possibly 285/35-18 tires. Front brake is Dr Diff "stage 4" with the Viper style 4 piston and 13" Baer rotors.
Q1: If I want to go to the lighter Hellwig bar then 55905 is my bar I assume?
Was debating going up to the 1.18" torsion bars, but want to drive it first.
On the rear, springs are mounted in the frame. Mini-tubs and some other clearance enhancements. Debating sliders. May run as large as 355/30-19. Dr Diff 11.7" rear brakes with Baer rotors.
Q2: Rear bar that fits is Hellwig 6908 (E-body) in my case? Does anyone have one mounted with the narrowed inboard springs and can show picture where end link attaches and clearance to spring?
That's what I did and it still came out a good bit cheaper than the Helwig. But if you ain't crazy about a little bit of mods and fab work......Don't waste time with the factory swaybar if you don't already have one — it's hard to find, too small and you can't easily replace the bushings. Hellwig makes a very nice kit. ADDCO makes an inexpensive bar, but the mounting bracket is grossly inferior to Hellwig's — I wouldn't recommend it (I have one but I completely reengineered the mounts and the end links).
Put a 340 in it. LOLLookin for opinions about the best sway bars to help handling with a 67 barracuda with a B engine. Thanks,no bars on it at all yet.
I can't offer help on the rear bar, I am planning to install the Hellwig A body rear bar on my mini tubbed Duster. But do you have more information on that steering shaft brace you show pictured?
