'72 Dart, would like to install a stock front swaybar, no brackets on lca. For the last hour I have been trying to research this, my head is ready to explode. Is there a weld on ready bracket or is my only option to modify the b/ e body bracket.
I apologize, I do not know how to look up threads on this site. I know that all of this has been gone over before, I have read some of them over the past 3 yrs or so, but did not take note of them because I did not have this car at the time.
So I will take a look at both suggestions and come up with a plan. Will probably go with the weld in.
Thank you everyone!
Stuff is going back on, much more fun. Hellwig 55917 sway bar (has the ends bent to clear the wheels better) Made the leaf spring hangers and plates. Qa1 front strut bar, new bushings, LCA plates, etc... Now trying to decide on which disc brakes to use.
Ordered an A body 8 3/4 housing and axles from Dr.Diff.
Nates68
Be careful. If I remember correctly, the 1972 factory sway bar runs through the k-member whereas the earlier ones have the sway bar in front of the k-member. I think the tabs that mount to the 72 lower control arms are different or are located differently than the 71 and earlier.
That being the case, you've got all the '69 parts- why not just exchange the LCAs for the '69 ones with the tabs? It doesn't take all that long, a couple hours including the mandatory beer break...I am installing an old stock swaybar from my '69 Dart, it seems to be the same. I put Gerst front suspension, all of it, under the '69. So it's all just sitting in the corner. Will try and get it set up per instruction, locate the brackets and weld.
I do not know how to locate or open that thread. I have an old front end to copy. Just didn't want to steel the lca from it.
Thank you for answering! We'll get it one way or another!
Just clarifying- *You mean LCAs...* (Lower Control Arms)Here is a thread about weld on sway bar brackets. If you scroll down you will see series of posts that I made with step by step pictures for modifying B-body brackets to use on A-body UCAs. It's not very hard, but not as straightforward as some other posters would have you believe because the A-body tabs are upside down and on the opposite side of the UCA as compared to B bodies (A-bodies on bottom of UCA - B bodies on the top of the UCA)
Search for:
Weld on sway bar tabs
