If your horn does not work, then look at the fuse area. (And the horn could fail to work due to other issues, but it is worth a check as it shares that same fuse as the park/tail lights.)
It will help if the OP answers this question on the front parking lights. If the front parking lights do not work, then the problem is in the headlight switch or connections.
If the front parking lights and or front side marker lights do light up OK, then the problem is likely in the side panel connector or further back; look at the black wire on postion #3 of the kick panel connector. And check where that black wire come out of the headlight switch connector.
If the license plate or either rear side marker light works, then that shows that power is getting through the kick panel connector. In that case, look at the tail light sockets and their grounds. Also look at the junction of six black wires in the rear harness where the rear tail, side marker and license plate lights all come together with their common power feed wire from the kick panel connector.
Here is your car's wiring diagram; it is pretty easy to trace this circuit if you start at the yellow and black wires coming out of the same contact on the lower left corner of the "LIGHT SWITCH" (shown near the bottom of sheet 2).
http://www.mymopar.com/index.php?pid=28
