Is there a place to install a temperature sensor besides the intake. Efi requires one and i want to run a temp. gauge in car.
The only thing I could think of is 90 degree brass tee. I'm thinking 3/8 npt, would have drill and tap intake but not a big deal, have already done that for heater hose, the only question I have since the sensor is not actually down in the intake would the sensors get a accurate reading.
A spacer for us thermostat?I saw a earlier post about spacer but never could find them, all I found was for chevy or big block mopar. Guess I'll go ahead with my tee.
That make an adapter that goes in the top radiator hose.
Jegs sells them.
@AndyF I don’t know if this will the “Magnum” water bolt hole spacing. Thermostat spacer with EFI sensor port | AR Engineeringandyf at arengineering has a space,r ar438, that may work for you. it is 49.00. take a look.
I think thats where i relocated heater hose. This a magnum engine and i'm going to use a/c which kills using hole underneath compressor.What intake manifold?
RPM?
On the center behind the thermostat (not directly shine it, just off to the right) there is a small hole that I drilled larger for a temp gauge sender. You can still use the stock sender in the intake about where it is normally placed.
Don't understand us thermostatA spacer for us thermostat?
Dang typo!A spacer for us thermostat?
yeah i'm a poor typer tooDang typo!
A spacer for THE or under the thermostat (“HOUSING.”)
Better?
i don't think i want to go that way
