You won't be sorry.I'm at 367 and it is awesome.373 cubes @ .040, yea, I can live with that one easy. I may try it soon.
I assume you're talking about the old TRW/Speed Pro pistons?
True, they are heavy. However, they were once all there was. People used them in droves. What you didn't see in droves were engine failures due to heavy pistons.
I am sure there were some, but nowhere near as many as pistons used. Bottom line is they WORKED and STILL work. Is lighter better? Yeah but it;s probably splittin hairs on all but the hottest of race engines.
I'm thinking about taking some weight out, any instructions anywhere that will help as far as how much and where to cut? Thanks
If you just look at the catalogs you are right... but most manufacturers can build anything you can dream of.I'm contemplating a 360 just for the piston availability.
