Babyblue66
Cool dude
It's not the fact they didn't fit as much as his attitude about fixing the problem. No options, absolutely no help, just "send them back".
That I fully understand. Had I known, I may have opened up the pushrod holes BEFORE the whole engine was assembled. Well, I learned two lessons. One about pushrod clearance, one about where not to shop.
I'm usually not one to bash a company, especially one I've used parts from before, but I'll never buy from Hughes Engines ever again. I purchased their 1.6 roller rockers for my 340 with J heads. There was no way you could put a push rod in because it rubbed on the cylinder head so bad it didn't line up with the ball on the rocker arm. He got mad at me when I was talking to him on the phone because his Parts didn't fit my engine. Then told me to send them back. Then I get charged 136.00 restocking fee, plus I lost shipping back, and tax. So all in all I lost about $200 to return rocker arms that didn't fit. But apparently that was my fault.
Is there any other reason besides money? That joey allows them to advertise on here without some kind of warning....I've had bad experience with Hughes also... I won't go into detail as it would be a little long, but like you, I won't ever buy from Hughes again...
Horse pucky!...Wow! Now you all have me concerned. Hughes custom ground (or had it done) a cam for my 225. I talked to Dave and messaged him several times through the process. I told him what I was building and what I wanted to achieve. He recommended the grind, springs and valve size. He made it quite clear to me about the break-in, using single springs for the first runs then installing the inner springs. Dave made it clear about using the special break in oil, etc. To some, his communication could come across a condescending, in my case, I was asking questions and for advice, so his shortness during the conversation was taken as "that's who he is." My 20 years in the Air Force exposed me to these types of individuals almost on a daily basis. Most were officers, or as Sgt. Micklin would say "college boys!"
Norm
BTW, I'm getting close to firing up the 225, as it is now on the test run stand I've made.
I really do like their rockers. Have them on both my engines.I will add, I don't think that I have heard anyone complain about the quality of the parts that they sell.
Well I understand how you feel, I guess I'm "sliced" a little different, until I get pissed off...but it takes a lot to piss me off.Horse pucky!...
90% of this forum could have told you what he said nicely with respect for your lack of knowledge...
I've worked with/for pricks and let them know about it in short order.... (got fired alot..)
The very last thing I want to hear is that's how they are cause. If now I'm supposed to put up with how they are, that's part of my job, I always say to them. What if when I walked up to you every day? I punched you in the face and everybody everybody just said, oh, that's how he is and who decides what's too much... here's an idea. How about treating everybody was mutual respect, especially if you're in a business and you're trying to shove your overpriced? Overpromoted parts you're getting from other people.I'm making a profit on...
Sorry, I went off the rails there and kind of got me started ...lol...
I've used three of their cams. All worked well. One is in my 66 coronet since 2006. I have no problem with the quality of the parts I've received. I've built a lot of mopar engines, but I still think these rockers were way off. It wasn't just a little grinding on the heads to make them work.Wow! Now you all have me concerned. Hughes custom ground (or had it done) a cam for my 225. I talked to Dave and messaged him several times through the process. I told him what I was building and what I wanted to achieve. He recommended the grind, springs and valve size. He made it quite clear to me about the break-in, using single springs for the first runs then installing the inner springs. Dave made it clear about using the special break in oil, etc. To some, his communication could come across a condescending, in my case, I was asking questions and for advice, so his shortness during the conversation was taken as "that's who he is." My 20 years in the Air Force exposed me to these types of individuals almost on a daily basis. Most were officers, or as Sgt. Micklin would say "college boys!"
Norm
I'm not an expert, but it looks like the adjusters in the rocker are out too far. That significantly affects rocker alignment on both the pushrod and valve side. My understanding is that you only want two threads or so exposed on the underside. Raise them up and that pushrod will be more in line, but need to be about an 1/8" longer.Here's the alignment. I used this hydraulic pushrod length checker to show how off they were. Also, the pushrod checker is laying on the side of the hole. This was not just a little bit off.
Yes they are out far, but all the way in didn't help much. And I tried shimming the shaft.I'm not an expert, but it looks like the adjusters in the rocker are out too far. That significantly affects rocker alignment on both the pushrod and valve side. My understanding is that you only want two threads or so exposed on the underside. Raise them up and that pushrod will be more in line, but need to be about an 1/8" longer.
My one experience with Hughes on the phone was not awe inspiring at all. The only reason he can get away with such a P-poor attitude with customers is that we don't have many sources for Mopar speed parts, like there are for Ford/Chevy.
Well takes a bit to get me upset as well, but just think, instead of them saying, send them back.They told you to just run it...?..Well I understand how you feel, I guess I'm "sliced" a little different, until I get pissed off...but it takes a lot to piss me off.![]()
You know what I am seeing here is that those adjusters are way way too far out...Here's the alignment. I used this hydraulic pushrod length checker to show how off they were. Also, the pushrod checker is laying on the side of the hole. This was not just a little bit off.
In mine, you can't even see the threads coming from under the rocker..
The farther you adjusted out the the closer it comes out towards the fulcrum...
