Guys - Have any of you ever used this stuff? https://www.summitracing.com/parts/...ummit-racing&gclid=CLf_zuOG29ICFdgGgQod6mMFoQ
I'm thinking about using it. My radiator seems to cool just fine, but there is a lot of corrosion build up in the radiator. In the spring next year I plan to upgrade the intake. At that time I would also replace the thermostat and radiator cap. So I was thinking the most appropriate timing would be to run the thermocure before installing those new items.
My question here is: Could the corrosion build up be plugging pin holes? And thereby using this stuff I would wind up unplugging pin holes? Or am I full of it? Thanks.
7milesout
7milesout
