Should look something like this? Mike
Pic is Weind, about 3 years old I think... Crosswind wasn't this bad but antifreeze seaping out the rear of it was and the machining was just silly bad.
I had the same problem with the intake manifold from BDS,had to send it back:angry7: All good now:toothy10:
My 169.95 (shipped might i ad) Crosswind intake was very nice & port allignment was pretty good, glad i past on the eddy RPM for 309.00 plus shipping, i don't care what some say, you guys would be "shocked" if you really knew the truth. If, I say IF those intakes are "truely" made in the states by Edelbrock, then Ol'e VIC needs his *** kicked & mighty hard, most of his high $$$ stuff ain't worth a ****!!!!!!!!! Your paying for the name anymore, i'm out 8)
Edelbrock has its' own foundrey in LA and it is run by Kristy, Vics' daughter. She keeps a tight rein on production, but it is not impossible to have something slip by once in a while. I know the family and they have no financial need to ruin their reputation by intentionally selling jusk to us Hot Rodders, who have made this company what it is today.
RALPH HORNBECK
SAN DIEGO
My point is they all have issues like that. You have to look for them, but that's why some engines run stronger and some don't even with the same parts.
Brian, what do suppose is the bigger power robber and why? A physical mismatched port opening (for this instance lets say its the top and pushrod side lengthst hat are off) or the change in volume as a result of the gasket matching and blending to the pinch? (ps - I'm curious what your opinion is... not trying to be an Ahole.) IMO, it's the mismatch.
In other words, if the opening in the manifold is close to the AREA or SIZE of the pushrod pinch AREA or SIZE then any matching will be void.
You know of course that there's a lot more to an intake runner than port alignment, right? The shape/taper/etc actually matters.
Crosswind is frigging junk. Its useful because it has the Magnum intake bolt pattern, and lets you easily hook up LA coolant tubing (when it doesn't leak). Thats about it. Anyone who has tried both (at the track, not just in the garage) knows that the Air Gap makes a lot more power (and mine was pretty well dead on out of the box).
You can set gaskets on an intake and ***** about the alignment till the cows come home, but it doesn't mean anything till you've seen what the port alignment is with the intake actually bolted to the head.
I've seen guys with sb mopar port matched heads, take the rpm or M1 intake off, port match it and either LOSE e.t. or not gain anything! I've never dyno'd it that way, but this leads me to believe that unless the pushrod pinch is mostly removed, the intake being SMALLER than the port opening is the best it can be.
Just what I've seen....
Why do you miss Offy ? Since when ? Called them lately ? ateam.rofilel:Oh, absolutely!!! Thats one of the reasons I collect every small port manifold I can, including the 22 degree marine single plane 4bbl. And also why I miss offenhauser. All their manifolds were smaller than the port. Or at least the ones I had got.
I have a Performer RPM here, bigger than the damn 4bbl gaskets, not exactly sure what good thats going to do me....... :angry7:
