I keep changing setups in my head so I started buying parts to force myself to one setup.But i have a couple of questions that i need advice on. Throttle size? 90mm, 95 mm or other? Injector size? Are the ID 1000's enough or more than i need? I purchased the efi intake manifold, and will be buying the intake elbow together with the throttle, once i know what size im going with.
Target of 550 & 600 hp mainly street. Its a 340 la. Fuel tech ecu, coil on plug, twin turbos, e85.
Im pretty sure ill keep changing my mind.
Thanks.
Thanks.
