tie rod dust boots?
n00blike
CA
Do i need them? I got a set of tie rods 2 inner and 2 outer but they didn't come with dust boots. do i need them? where can i get some?
i have bought them from summit racing and i have bought them at autozone from the HELP section.
Energy suspension makes poly ones that won't tear as easy.Cheap to, like $9.00 for a pair. Yes you should use them or the sand/dirt & road grime will take those joints out pretty fast with nothing keeping them in grease.
Should be able to get them at any cheap auto parts store...You don't need the Polyner ones but if you do get them make sure to get the POLY-GRAPHITE ones..That way they wont squeak..
SS
Where did you get the Tie Rod Ends that DON'T Come WITH the Boots/Maybe they were taken out.....
SS:sad1:
yeah mine are all torn up and i got the kit from p-s-t.com thanks for all the help
what size should they be?
hxxp://cgi.ebay.com/ebaymotors/Energy-Suspension-9-13105R-Bushings-Tie-Rod-Dust-Boots_W0QQcmdZViewItemQQcategoryZ42609QQihZ012QQitemZ220378098107QQrdZ1QQsspagenameZWDVW
Replace the hxxp with http.....
It depends on what size your shaft is BUT I believe these would be it unless you have 1/2" shaft...
I would probably get back ahold of PST .COM andtell them you ordered them from them and you need Dust Boots...MAYBE they just forgot to put them in..Or maybe they will give you a special price since you already bought the TR off them..They SHOUL know from your part #'s/Application which is correct for you...
SS
so i was digging through my parts room (closet) and getting things ready for a spring break full of working on my car and a found a box with...the dust boots, grease fittings, nuts, and clips. so yeah all is ok now! my bad
:headbang:
:headbang:
Cool Deal...Rock On Brother....
SS
:toothy4::wav:
