Tie rods, steering and disc brakes???
Sorry @72bluNblu
I forgot to ask, if swapping to 11/16 tie rods(inner and out)....would i have to swap my center link as well??
I can answer that.
The tie rod ends will work with either center link.
The center link needs to be paired with the correct pitman and idler arms. 1972 and earlier, with changes the earlier you go. 1973 to '76 need to match up also.
Thank you once again @72bluNblu
So im going to have to return the Hellwig 5906 lol
Full disclosure, I did call Hellwig and asked them about that bar fitting while I use the QA1 LCAs...they said it would work. They also mentioned possibly have to shortening the end links bolts....But im unsure if they have actually tried this configuration.
I feel more comfortable trusting your judgment on all of this.
Luckily I ordered it from summit and they're awesome on returns/exchanges and sending the actual part i need the next day.
The easiest bar to order next would be the QA1 bar but the ones they sell/have, u either need to have their tubular K-member or have their coilover conversion.
The next one would be the Hotckis bar, it is thicker at 1-1/2" and requires welding(from the instructions) and im not proficient at welding but worth the try. Unfortunately summit doesnt have or carry the Hellwig #55917, or id go with that one. But then again idk if im going as wide with the wheels, yet.
And as for the Tbar, I'm gonna order the 1.12" from FF, definitely want to try those out.
Yeah the QA1 sway bar only works with the QA1 k member.
Shorter end links won’t cut it with the 5906, the bar is several inches longer so it can’t use the inner/73+ sway bar mounting tab locations.
The Hotchkis bar does have brackets that weld to the K frame, but as far as welding goes it should be pretty simple. And the QA1 LCA sway bar tabs can locate the sway bar to help with the k frame brackets.
The Hotchkis sway bar will allow for wider tires as well, and for the 55917 it’s not about the wider tires, it’s about the sway bar tab locations on the QA1 LCA’s. Both the 55917 and Hotchkis bar can use the sway bar tabs that come on the QA1 LCA’s. Any bar that uses the factory 67-72 sway bar tab locations won’t fit with the QA1 LCA’s.
Sorry @72bluNblu
I can answer that.
Exactly. The taper diameter on the 11/16” tie rod ends is the same as the 9/16”. The adjuster diameter is the difference.
I can answer that.
Awesome thank you @S'cuder
So I'll be good with either tie rod and using my existing drag link. The only other thing is that I did order a new idler arm from Proforged... Proforged Chassis Parts 102-10035 Proforged Idler Arms | Summit Racing
Will i have any issues there??
Thank u and Merry Christmas!
Thanks again @72bluNblu
I'll order the Hotchkis sway bar this weekend and do a little welding
It should be alright, I hope lol
And like you & @S'cuder mentioned, I'll be good with either tie rod...I might go with 11/16s in the end. Also any input on the idler arm I order, since my steering box will be stock for now and keeping the original drag link.
I'll update you gents soon and let u know how this process is going.
Thank you again and Merry Christmas!
Im looking into Hotchkis and QA1s...do u have any suggestions?
with the 1.12's i think i'd want something adjustable. fox or qa1 would be my choice.
if it hasn't been covered already, subframe connectors and frame stiffening is something that you should strongly consider.
Yeah definitely leaning towards adjustables...and leaning towards qa1. Thank you :)
And yea, we did touch on it a bit in previous posts here...that will come into play once I get the new drive train in. Im hoping for something around 400hp and possibly doing some autoX
That looks like a decent piece. Proforged is one of the best brands of suspension and steering parts that are readily available for our cars. There were many. Now there are few.
Very true, if it wasn't for the community here at FABO, id be lost.
So thank you and all the gents here replying to me and my questions.
