Timing pointers
jhnycuda
Lancaster, Ca.
Hey guys, has anyone measured the distance between the TDC points from the pre-69 (pass side marker) to the 70 and later (drivers side marker) on the balancer. I am using the early style cover and water pump with the bolt on tab, but using a balancer for a later engine, I measured and marked the balancer 5 years ago when I built the engine, want to double check it but no longer have the later balancer and cover to check against.
Man it’s been probably 40 years since I marked one this way but 2 3/8 sticks in my mind for 36 degrees
I scribed a new line on the new balancer to be able to check timing on the bolt on tab on passenger side, installed a timing tape around the balancer, been running warm and want to double check everything, planned on driving it to the Duct Tape drags on Friday, Lancaster, Ca to Tucson, if I don't get things sorted, I will take my '12 RT Challenger. It is supposed to be 102 there on Friday and Saturday.
Just use a piston stop to check TDC. That way you KNOW. You can check the degree markings, if you don't have a degree wheel, by carefully measuring around the balancer with a flexible tape, than calculate the distance vs degrees
I've marked several unmarked balancers, not that hard
VERY unscientific....
4 13/16"
I rotated my crank till it was on TDC on the 67 pointer.
I marked the damper at the 0 on the 70 up pointer.
I put some masking tape around the damper and marked the two TDC marks (should have done that first)
I took the tape off and laid it out flat and measured.
NOT accurate enough to scribe your damper but gets it in the ballpark
4 13/16"
Thanks, thats about what I remember checking 5 years ago, wanted to double check everything but no longer had the 70 style cover laying around.
