Comes with advance, retarded, or spot on for crank gear positions.
I know this engine has a stock can, and the stock rotation before diassembly aligns with the straight cut on the new set.
Even with a stock camshaft, stock everything, could I still use the other cuts to move my torque band or do I need a different cam grind?
I need it as low as possible. Below 3000. 3500 at the most.
Thanks.
Thanks.
