Forgive my ignorance, but I am pretty unfamiliar with the Chrysler 400. It seems like this is a great engine to build if you're willing to replace the bottom end, mill the block or the heads, etc.
The problem is that I went a little over budget on the '67 Barracuda that I picked up and I really don't have the cash to make expensive modifications like that. Does anyone know how to get some decent HP, say 350 or so, out of a 400 using stock internals??
It already has some long tube headers, an Edelbrock carb, and a decent cam (.442int, .465exh, 214* int @.05, 224* exh @.05).
I would like to add a Performer RPM manifold and Performer RPM 84cc heads with a 0.020 compressed thickness head gasket.
Does anyone know what kind of compression ratio and HP this might yield? Any other suggestions for a low-budget build that doesn't require pulling the whole engine?
Thanks guys!
Thanks guys!
