Okay take a look, I fixed her up my self.... The sway bar any how... I'll be posting photos of my bushings shortly.
My upper ball joint bushing is visible what do you guys think replace upper bushing only? I'm thinking replace entire ball joint. These control arms had over 40 years of Gunk... Inch thick
^^^ Good story! Hope it convinces some folks.
whatever you decide make sure you by upper and lower ball joints for a 73-up disc brake abody.
all the moog part numbers so you can just order from rock auto.. http://www.bigblockdart.com/techpages/moognumbers.shtml
Yes. Those are 73-up disc brakes it looks in your pics.
Dart or duster. If you look at my parts list above that's everything us need.
i was setting everything up but three things got me a little lost when ordering. the control arm bushings 2+1 and the LCA 4 on your list there.
here ya go.. the parts for your front end.. looking at $300 +shipping from rockauto..
Joe, again thanks for going through the trouble with this.
I just ordered a complete front end rebuild for my 74 Scamp with all MOOG parts like you suggested - minus the lower/upper arm bushings and upper ball joints (I'm converting to the tubular type, so they're not needed), from Summit for $237.65 w/free shipping.
And that total included the upper ball joint socket.
I don't know what i'd do without the helpful people on this board.
Is that picture on the left of your signature in Wildwood????
ciao - Saverio
You cannot/must not arbitrarily crank up the T-bars, without a corresponding re-alignment. The factory specifys a front ride height that puts all the relavent parts in working harmony. Changing the ride height affects the harmony, requiring a new alignment; every time.
-Bear in mind that there is only a small amount of suspension travel available between the oem bump-stops. So if you crank it to the top, you will have zero rebound travel.And,This pulls the top of the tires in, creating mucho negative camber. And mucho toe-in.
-Also bear in mind, that as the rear goes up, you lose caster in the front. If you start at/near zero( as the factory did) the caster goes negative;great for slow speed maneuvers,but lousy for higher speeds. And thats where the offset UCA bushings can help.
-If you are unhappy with the elevated rear, a better idea is to lower the rear,and restore the front to be in its proper working range.
-And "stiff and bouncy" has got me puzzled.Yeah those springs are stiff, thats why theyre not on my street car. But bouncy? Are the shocks ok? I bet your shocks are not matched to those springs.
-I installed a set of re-arched HD318 car rear springs to which I had the spring-shop add 1 main leaf, eye-to-eye.Subtle stance,and I can hammer over speed-bumps without banging my head on the headliner.Then I installed 1.03 T-bars,dropped my front-end a tad, and re-aligned.Nice stance, nice ride, nice handling, great tire life, Not so good 60fts; but hey, its a daily-driver.Worked out excellent for me.If it was a weekend bomber, different set-up. Or track-car,different again.
-What are you focusing on?
Ss springs do sit high and do t have a great ride in my opinion. If you raised the rear a good amount it will throw your alignment off.
Cranking g the torsion bars up can also throw the alignment off.
What bars are in the car? If the bolts are all the way in it may be time for larger bars.
