Tiss the season
Cledus
Kalamazoo Michigan
That time of year to get some christmas cheer on and spend time in the basement with the die grinder.
Set of 308's im porting getting ready to template the bowls but figured i would start on the intake runners I pre tubed the push rod hole in case i got to agresive on the pinch. here is where i am at so far should i leave and move on to the next section or should i keep working at them till i get to the tubes thanks a lot guys.
Best thing to do is save the port window for last. Dont go deep when gasket matching except for the siamese wall, leave the pinch alone till you see decent shape at the ssr and bowl. Now try and get those windows in shape , though some are cast off to one side and or pocked ..like this..Have fun.lol
Tip, grind at an angle tip up to the marked line...then lean down. You get straighter lines. If you're really into it you can file finish the lines edge.
