I meant jack the arm up enough to get the bumper out then let it down again.
It should drop far enough to release the torsion bar tension. Only thing left catching it might be the shock absorber. If you have to remove the bolts from the upper arm to get that assembly to drop further, the torsion bar probably wasn't installed properly.
