Trailduster 904 into a Dart?
fenderman33
Portsmouth, VA
I'm looking around for a small block 904 that I can bolt up to a 318 LA I've got running around. I have come across a "good used" one from a 1990 Trailduster he says. Will any 2 wheel drive small block 904 fit in the a bodies or are there physical differences like with the 4 speeds?
If that won't work, what do I need to be on the look out for?
Thanks,
Jon
AS far as I know, it'll work. You might check the numbers on it, and/or the torque converter, since it may be a lock up unit. That would be something you might, or might not, want.
