for the rough alignmentmaxing out camber? i went with .5* as much caster as possible though
As someone without specialized equipment and who doesn't care that much, my procedure is the following:
Use offset bushings
Start with front all the way out and back all the way in
Set toe kind of close (within an inch)
Get camber in spec by moving only one adjuster on each side (this will ensure maximum caster)
Set final toe spec
Roughly check caster with a level to make sure it's at least in the positives.
Drive and see.
yeah i would like some slip plates.. but can get by without them... i was shocked how good my first alignment drove.. i need to redo it since i made some changes though
will try thatI use kitchen floor vinyl tiles, using Mazola or similar between, - easy to clean, easy to store.
Cheers
I did something similar - cut some 1 x 1 sheet metal pieces and put grease between them. I haven't given them a good try yet but will this winter.I use kitchen floor vinyl tiles, using Mazola or similar between, - easy to clean, easy to store.
Cheers
Yeah it works well and super low effortThat's exactly how i did it, i did the front adjuster all the way out though and used the rear to set camber so i could have as much caster as possible
Yep, or 4 cut pieces of Lexan/polycarbonate, a shot of cooking spray between....I use kitchen floor vinyl tiles, using Mazola or similar between, - easy to clean, easy to store.
Cheers
I used sand. No mess, compared to grease, etc.I use kitchen floor vinyl tiles, using Mazola or similar between, - easy to clean, easy to store.
Cheers
How about this??Anybody made some wheel clamps for attaching a magnetic level? I'm looking to make something rather than buy.
Long, woodworking clamps might work as well. Add a plate for the magnetAnybody made some wheel clamps for attaching a magnetic level? I'm looking to make something rather than buy.
The factory spec for A-bodies is 0* to Neg 1* caster, - just like the front wheels on a shopping buggy, absolutely NO directional stability, wobbbly at best.
Skosh chart is a great help on all vehicles.
I prefer a little more caster (not a tire wear angle) passenger side to compensate for "road crown".
I bought 2 small white cutting boards (HDPE) from the dollar store, made a grease sandwich. Same principle as the other examples, different way to get there.Yep, or 4 cut pieces of Lexan/polycarbonate, a shot of cooking spray between....
I like that idea, think I'll give it a shot next time.I used sand. No mess, compared to grease, etc.
Anybody know if anyone besides Moog is making offset upper bushings?
