Do you have the part number for the Brewer's fork that you used? Never mind, did not see there was a page 2.
Parts you will need is
TS 636 Torque shaft 63-66 A body w/10.5" clutch
FP484 Fork Pivot
CF702 Clutch Fork 63-66 10.5" conversion
You will also need the ball stud kit which includes the ball stud/bracket for the bell housing and a stud you will have to weld to the stock frame bracket.
You will need to call Brewers to insure the part numbers are correct. They can set you up with everything you'll need.
937-698-4259
