DR HEMI
Man on a Mission
No Shzit! He's not a real boy!Looks like a Robot welded it! Nice work!
**** looks good!
Is there a taper in that lower rod end to accept the ball joint?
Yeah, i figured out the closest hole size i needed then used a tapered reamer for mopar ball joints.
I knew you were on it like that!
I got these from Prothane,they are a universal pivot bushing. These have the largest shaft diameter available which is why i went with them. I think it's nice to have a component that has some give to it without bending the other components if its hit hard, such as a pot hole or coming down from a wheelie etc.
Did you make attach points for the strut rods? Didn't see them in the pics.
I can't tell but you may want to put misalignment bushings on the a-arm end of the strut bar bolt.
