Looks like your well on`your way so i dont know if this will help but ive built a few of these my self.I cut the flange off the header and flipped it so the headers went up and forward instead of down and back..Good luck ben
Good job Louis, it looks right now. Lets see 10 pounds of sh&t in a 5 pound bag! 160lb injectors are huge but I have a feeling you are going to need all that fuel. Ramit, I would be careful running that big of an injector with two t04s. When the injector is that big it can be tough to get it to idle well. Low speed will be soggy too. I run a 96lb injector in my small block and have them at 80% at full boost at 7k.
instead of replacing the plug why dont you get a tool to remove the pins from the plug and just switch them. it will be alot nicer looking, and it will be cheaper. and you get a new tool out of the dealWell all my parts are here to finish up the Fuel Injection. The intake finally got here, the injectors, fuel rails, all the an fittings, Mallory Boost referenced Fuel Pressure Regulator, Fuel pressure gauge etc.
I also got the NEW TPS and it tested the same as the others Wide Open 5+ ohms reading at Closed Throttle and .020 ohms Closed reading at Wide Open. So I did some research and learned that you can reverse the +5V wire and the ground to get it to send the correct signal. If you used the factory plug on the TPS to wire it up you would always be confused so I will be cutting off the factory plug and wiring in my own male and female plugs to fix this issue. Funny cause I researched TPS's for a long while but was not bright enough to google TPS wired backwards which helped me find the problem. I tested it on the bench this way and BAM it is good to go! :cheers:
I should hopefully start on the fuel rails etc tomorrow and start posting some more pictures. We will see!
instead of replacing the plug why dont you get a tool to remove the pins from the plug and just switch them. it will be alot nicer looking, and it will be cheaper. and you get a new tool out of the deal![]()
man thats a great price on them i thought the ones that i found here http://www.mcmaster.com/#weather-pack-connectors/=a8tvnr were a good price but yours are cheaper. i just assumed that you had both connectors already. i geuss thats what i get for assuming....
i like this kit http://www.diyautotune.com/catalog/....html?osCsid=9f2e0a801735b01860430354b63190f2 ill have to order it when it comes time to rewireing my car.
Ahhhhh Hell!!!
Cut the hood and be done! LoL!
Yeah I seriously contemplated doing just that...........then I thought I have came this far just make the intake elbow and quit crying you sissy!! :crybaby:
I know its your car now,but man, please dont cut the hood.
I bet Wade could fab up a good one for you.
