Uh NASA we almost had a problem
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I was nosing around under my dart today. I noticed something odd.
It was little more than finger tight.
I always use locktite for insurance because I had one come off while going down the road....luckily I was only doing 30MPH but was still very scary!!
Treblig
Not sure who put it on, it looks new. Been driving it this way for about 8 months even on the interstate. Makes me wonder what else is loose
That pitman is pressed on pretty good, It may have lasted longer than you think but nuts are made to be TIGHT! Good policy is to check everything down there when you do an oil change, while waiting for the pan to drain. Good catch.
I will be doing a down under double check in the near future!
