1. Samsquanch
    Samsquanch Active Member
    25
    17
    Apr 2, 2021
    Cobbs Creek Virginia
    Local Time:
    10:10 AM
    I recently acquired a 1977 LA 360 block and discovered this in one of the lifter bores. Some one please tell me it's no big deal PLEASE!!!! I was planning on building a stroker out of it but I think I'm screwed with this block. paid $300 for it. My guess is it's a gonner. Let's say I have to buy a new short block from an online dealer, what 360 (408) while mount up in a 1968 Barracuda with minimal if any altercations?
  2. Dana67Dart
    Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
    9,932
    7235
    Jul 16, 2017
    Northern Colorado
    Local Time:
    8:10 AM
    Wonder if lifter bores can be sleeved?
    Might be weldable or brazed to make a repair.
    Your last photo almost looks like someone put a pin left to right through the crack
    goood luck
    • Like Like x 1
    • Samsquanch
      25
      17
      Apr 2, 2021
      Local Time:
      10:10 AM
      I think the crack across the top of the lifter housing pretty much does me in for sleeving it but who knows maybe someone who has had this problem will chime in
    • Dana67Dart
      9,932
      7235
      Jul 16, 2017
      Northern Colorado
      Local Time:
      8:10 AM
      I remember seeing a post in the last year about a hole in a lifter bore that looked just like that one. Don't remember there being a crack though.
    • Samsquanch
      25
      17
      Apr 2, 2021
      Local Time:
      10:10 AM
      The hole almost looks like a casting flaw but I think crack is bad mkay (sorry couldn't resist the south park reference)
      • Like Like x 1
      • dano
        dano Evil Handy Man
        4,390
        2244
        Aug 22, 2005
        Gresham, Oregon
        Local Time:
        7:10 AM
        It can probably be brazed and bushed. It just depends on how much your willing to spend to fix it and what other issues it may have. The second picture show what looks to be a heat issue?
      • Samsquanch
        25
        17
        Apr 2, 2021
        Local Time:
        10:10 AM
        That scares me, A heat issue? I'm probably better off just buying a short block from jegs, summit or someone like that so less worries
      • MoparLeo
        MoparLeo NRA BENEFACTOR LEVEL LIFE MEMBER FABO Gold Member
        1,184
        860
        Feb 10, 2016
        Moreno Valley, Cal. So. Cal.
        Local Time:
        7:10 AM
        If the casting is thin in this area, where else in the casting might there be a weakness ?? I would pass on this block. They are cheap and not real hard to find.
        • Like Like x 1
        • Agree Agree x 1
        • Samsquanch
          25
          17
          Apr 2, 2021
          Local Time:
          10:10 AM
          I agree better safe than sorry, the good news is the guy I bought the block off of is giving me back my money
          • Like Like x 10
          • Agree Agree x 1
          • Samsquanch
            25
            17
            Apr 2, 2021
            Local Time:
            10:10 AM
            Thanks moparleo, I'm going to take your advice, anybody wanna buy a used 360 block? lol
            • Thanks! Thanks! x 1
            • dano
              dano Evil Handy Man
              4,390
              2244
              Aug 22, 2005
              Gresham, Oregon
              Local Time:
              7:10 AM
              Look to Blue Print Engines, they are a supporter of this site.
              Chrysler Compatible Crate Engines
              • Agree Agree x 3
              • Like Like x 2
              • 33IMP
                33IMP Well-Known Member
                3,009
                3266
                Jul 3, 2020
                Taxifornia, soon 2b arizona
                Local Time:
                7:10 AM
                I think that is the best possible outcome. I was gonna suggest investigating if it could be welded, and how much. Money back, solves the problem.
                Edit: second the rec for Blueprint. I have never seen a bad word about them. Im gonna buy either a 540 or 598 from them.
                • Agree Agree x 2
                • Like Like x 1
                • Ron816
                  Ron816 Mopar forever
                  587
                  750
                  Nov 15, 2019
                  Quincy, MA
                  Local Time:
                  10:10 AM
                  Use it as a mooring anchor
                  • Samsquanch
                    25
                    17
                    Apr 2, 2021
                    Local Time:
                    10:10 AM
                    might make a table out of it like i saw on topgear
                    • Like Like x 2
                    • Samsquanch
                      25
                      17
                      Apr 2, 2021
                      Local Time:
                      10:10 AM
                    • diymirage
                      diymirage HP@idle > hondaHP@redline
                      29,131
                      29255
                      Oct 12, 2012
                      michigan
                      Local Time:
                      10:10 AM
                      • Samsquanch
                        25
                        17
                        Apr 2, 2021
                        Local Time:
                        10:10 AM
                        Thank you very much for the hook up, I'll message him and see what he can do
                      • Scody21
                        Scody21 Just send it
                        2,054
                        2512
                        Jul 17, 2019
                        Southwest Washington Coast
                        Local Time:
                        7:10 AM
                        It’s hard to build a warmed up motor for less than you can pick one up from BPE. Unless you have the tools and skill set to rebuild yourself and sub out the machine work..
                        • Agree Agree x 3
                        • 512Stroker
                          512Stroker We are all here because we are not all there.
                          3,381
                          2758
                          May 30, 2016
                          Freedom, MO
                          Local Time:
                          9:10 AM
                          Look like you got ya a "Boat anchor" there.
                          • Like Like x 1
                          • diymirage
                            29,131
                            29255
                            Oct 12, 2012
                            michigan
                            Local Time:
                            10:10 AM
                            My pleasure
                            The way I notified him, he will know we were talking about him, so he will see this thread
                            • Like Like x 2
                            • dano
                              dano Evil Handy Man
                              4,390
                              2244
                              Aug 22, 2005
                              Gresham, Oregon
                              Local Time:
                              7:10 AM
                              Supply chain is a mess for all industries. Probably not out of stock but more like on back order as parts come in. I guess it depends on how long you are willing to wait.
                              • Agree Agree x 1
                              • replicaracer43
                                replicaracer43 Grumpy Old Man
                                5,467
                                5419
                                Oct 10, 2008
                                Local Time:
                                9:10 AM
                                If your looking for a 408 shortblock, I'm in the process of building 5 of them, although the blueprint engines are top notch, and @Johnny Mac can give you all the answers and customer service you could ever want. I am a one man machine shop/engine builder, if I can help you, feel free to PM me...
                                • Like Like x 2
                                • Johnny Mac
                                  Johnny Mac www.blueprintengines.com FABO Vendor
                                  4,082
                                  3455
                                  Jul 10, 2010
                                  OHIO
                                  Local Time:
                                  10:10 AM
                                  Thanks everyone for tagging me in. You guys Rock!! With the industry the way it is at the moment, we have paused Shortblocks. Every spot on the line is needed for longblocks and complete engines. That being said....if you don't already have a nice set of aluminum heads sitting there, or if you need machine work, etc, I can't see anyone being able to buy new parts and set them in a pile on the ground, for what we deliver a dyno tested, warrantied, engine for.
                                  so again to clarify, we are still building longlbocks, and complete engines, and complete drivetrain packages. the shortblocks, are whats on "hold" for the time being.
                                  everything in this link is available, besides the stripped shortblock. we just have long lead times, like everyone else right now.
                                  BluePrint Engines
                                  • Like Like x 2
                                  • brian6pac
                                    brian6pac Legandary Member Legendary Member
                                    5,668
                                    4035
                                    Nov 15, 2016
                                    N.E.Ohio
                                    Local Time:
                                    10:10 AM
                                    The way it looks to me is a bad casting, the crack looks like it just goes through to the hole so it wont go any farther. I would be worried about a piece coming off of it though. It could be repaired but might be to costly to make it worth your while.
                                    You should be able to find a used engine cheap.
                                  • MoparMike1974
                                    MoparMike1974 FABO Gold Member FABO Gold Member
                                    3,916
                                    3369
                                    Jun 16, 2017
                                    Maryland
                                    Local Time:
                                    10:10 AM
                                    Looks like a pourous casting and was probably like that since it was made. Its fixable but being a 360 the cost of another block would probably be the cheaper route.
