Universal steering couplers
Suspension, Steering and Chassis
  1. pishta
    pishta I know I'm right....
    16,505
    6190
    Oct 13, 2004
    Tustin, CA
    Local Time:
    3:26 AM
    on a 65, the column is held on with a 2 bolt strap at your knees! A rigid mount would just slide the steering column in and out a few mm's. If your welding...how about a 3/4 drive U-joint? Weld a socket on the steering shaft and have a removeable "snap in" column.....nuts? You AINT gonna break it! (4000 in/lbs)
    Looks like weldable steering U-joints are cheaper than these......
    • Like Like x 1
    • Belvedere66
      Belvedere66 Well-Known Member
      123
      19
      Jan 17, 2015
      Amelia, Ohio
      Local Time:
      6:26 AM
      That's actually a really good idea because I've been trying to find and 11/32 Cobalt bit to drill a hole in the stainless steel coupler I purchased. But the pain is a oddball size how did you get a 3/8 bolt to fit snugly in the factory pin hole? I would have to probably tap the shaft and just make a smooth bore hole in the coupler because trying to tap stainless would be difficult.
      • Like Like x 1
      • Belvedere66
        123
        19
        Jan 17, 2015
        Amelia, Ohio
        Local Time:
        6:26 AM
        So I've run into a slight snag. is there a way to remove the dowel pin at the end of the shaft without having to remove the entire column? I know it is in there pretty damn good but I don't know if anyone has had any luck getting it out while still on the car.
      • Belvedere66
        123
        19
        Jan 17, 2015
        Amelia, Ohio
        Local Time:
        6:26 AM
        I used some garage ingenuity and fashioned a hand press out of a ball joint tool and some shortened bolts and thick washers. Dowel pin out, didn't have to remove my column to get shaft out. I'm going to tap the shaft, and use a 3/8"-24 set screw with loctite. My universal is stainless steel so I didn't think my tap bit could do the job so I was just going to drill a normal 3/8 hole and let the set screw fit tightly inside it on each end. The loctite should hold the screw in indefinitely but I could realistically take it apart if I ever needed my shaft out for whatever reason.
        • Like Like x 1
        • moparmandan
          moparmandan FABO Gold Member FABO Gold Member
          2,128
          1973
          Jun 28, 2017
          Central FL
          Local Time:
          6:26 AM
          Sorry for the slow reply. Sounds like you got it though. That's exactly what I did, except my column was out. Good job on the dowel pin tool! Post a pic!
        • jos51700
          jos51700 Well-Known Member
          5,177
          1858
          May 24, 2009
          Bel-Ray
          Local Time:
          5:26 AM
          Hmmmmm, dick with the factory-designed steering system that's engineered with my safety in mind, or dent the aftermarket headers that are so poorly designed they don't fit in the first place.
          Hmmmmm dent the headers or add a part that's not designed for axial loads transmission and apply repeated cyclical axial loads ...hmmmmm
          Dent vs. Safety. Hmmmmm
          Dent vs. Safety. Hmmmmmm
          Yeah I'm outta idears on this one. Weld up the slip joints on your transmission output shafts while you're at it. The drive shaft will just flex and it'll be fine. Then you can brag that you did it better.
        • moparmandan
          2,128
          1973
          Jun 28, 2017
          Central FL
          Local Time:
          6:26 AM
          People been doing it for years. Don't be sceerd.
          • Like Like x 2
          • Tooljunkie
            Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
            13,185
            11887
            Jul 22, 2017
            Manitoba
            Local Time:
            5:26 AM
            So i guess saving steering u-joints from cars that have two was a good idea after all. the u joint in the engine bay fails, the one under dash is like new.
            some are slip-shaft style so i have the necessary parts to weld in. Or i will mill off the splined end and weld it to the better u-joint.
            Did that on a dodge pickup about 20 years ago,still there still perfect.
            • Like Like x 2
            • Belvedere66
              123
              19
              Jan 17, 2015
              Amelia, Ohio
              Local Time:
              6:26 AM
              Well I guess all of these people who have done it and all of the companies who sell these style steering joints are just killing everyone. My 2019 Mazda has a universal steering joint, as did my 2017, 2015, my 2000 Celica, my 11 Scion, our 07 and 19 santa fe's.....etc etc. I guess they are deemed not as safe as some shit coupler box designed by the same people who thought of bulkhead connectors, reverse thread lugnuts, and ammeters. I'll take my chances with my setup. I've got plenty of guys who supported my idea who have a lot more experience than I. Or pull engine just to get some crappy headers off that I don't plan on keeping anyway. I've tried map gas and lots of tools to try to dent the header pipe in, that was my first plan. So.....✌️
              • Agree Agree x 1
              • Belvedere66
                123
                19
                Jan 17, 2015
                Amelia, Ohio
                Local Time:
                6:26 AM
                Yeah thanks for the idea man, I have a machinist working on all of the drilling and tapping tonight
                • Like Like x 1
                • moparmandan
                  2,128
                  1973
                  Jun 28, 2017
                  Central FL
                  Local Time:
                  6:26 AM
                  Good! Be careful in that death trap. Lol
                  I'll be out putting drum brakes on and cutting my steering u joint out of my car.
                  • Like Like x 1
                  • Belvedere66
                    123
                    19
                    Jan 17, 2015
                    Amelia, Ohio
                    Local Time:
                    6:26 AM
                    Here's a crude picture of the tool I used. And I was mistaken it was a tie rod end tool not ball joint. Similar but smaller I believe. Worked pretty great actually. Newborn and wife were sleeping above me so couldn't use any punches or hammers anyway.
                    • Thanks! Thanks! x 1
                    • furyus2
                      furyus2 Well-Known Member
                      2,075
                      606
                      Oct 30, 2010
                      weeki wachee fl
                      Local Time:
                      6:26 AM
                      :popcorn:
                      • Like Like x 1
                      • Belvedere66
                        123
                        19
                        Jan 17, 2015
                        Amelia, Ohio
                        Local Time:
                        6:26 AM
                        Also will be using this ER-16 flange bearing for the lower bearing instead of replacing the crappy plastic retainer that's currently missing.
                        • Like Like x 2
                        • moparmandan
                          2,128
                          1973
                          Jun 28, 2017
                          Central FL
                          Local Time:
                          6:26 AM
                          :thumbsup::thumbsup::thumbsup::thumbsup:
                          Works great!
                          • Like Like x 1
                          • Belvedere66
                            123
                            19
                            Jan 17, 2015
                            Amelia, Ohio
                            Local Time:
                            6:26 AM
                            Did you just tap in in with a socket or something? Haven't tried anything yet, picked it up during my lunch break
                          • moparmandan
                            2,128
                            1973
                            Jun 28, 2017
                            Central FL
                            Local Time:
                            6:26 AM
                            Yep it's pretty snug, so if your column is rusty it will take some work with sand paper and a file to get a good fit. Then grease it up and tap it down with hammer and flat punch.
                          • jos51700
                            5,177
                            1858
                            May 24, 2009
                            Bel-Ray
                            Local Time:
                            5:26 AM
                            People think metal fatigue don't be like it is but it do. Have fun.
                          • Belvedere66
                            123
                            19
                            Jan 17, 2015
                            Amelia, Ohio
                            Local Time:
                            6:26 AM
                            Ok thank you for your expert opinion. I'll put that thought on the back shelf with my ex-gf's birthday and what I ate for breakfast last week.
                          • furyus2
                            2,075
                            606
                            Oct 30, 2010
                            weeki wachee fl
                            Local Time:
                            6:26 AM
                            Since my 69 Dart has a collapsible steering column , wouldn't that take care of the flex that people worry about?
                            • Agree Agree x 2
                            • moparmandan
                              2,128
                              1973
                              Jun 28, 2017
                              Central FL
                              Local Time:
                              6:26 AM
                              There are those that say that is enough. I'm one of those living on the edge rebels. There are those that say no, Ma Mopar had it right from the factory. Stay away from the aftermarket u joints or design in a slip joint.
                              Your choice. I ain't arguing about it anymore. Other guys feel the same way and don't even respond to these threads anymore. Think I'll join them.
                            • jos51700
                              5,177
                              1858
                              May 24, 2009
                              Bel-Ray
                              Local Time:
                              5:26 AM
                              I can see why she broke up with you.
                            • thesiren74
                              thesiren74 Well-Known Member
                              1,125
                              690
                              Feb 23, 2014
                              kenosha,wi
                              Local Time:
                              5:26 AM
                              So i guess all those aftermarket u-joints they use in a bunch racing series just fail all the time? Maybe they should use the state of the art mopar coupler you know for safety.
                              • Belvedere66
                                123
                                19
                                Jan 17, 2015
                                Amelia, Ohio
                                Local Time:
                                6:26 AM
                                I broke up with her in 2011 but ok weird flex . Now we have personal insults. I think you need a timeout in the corner.
                              • jos51700
                                5,177
                                1858
                                May 24, 2009
                                Bel-Ray
                                Local Time:
                                5:26 AM
                                When your chassis is as rigid as a 'caged race-car, it's not required. When your car has a hundred thousand miles on a structure that wasn't stellar to begin with...well, someone makes it so you need to install it.
                                All I did was compliment her tastes. Sorry I hurt your feelings.
