valve lash setting
Abodies Only
New Member
Calgary
I purchased a rebuilt motor complete less the tin. My question is without knowing the cam what is the lash setting I should use. It is presently set at .018 and .018 thanks in advance Brent
You're welcome, but I don't understand the question. 0.010" is the factory spec for the intake lash.
Hi Dan I’m not sure what the cam is if it’s factory or been upgraded I bought the motor in crate with no information other then it was rebuilt
Giving our friend, Dan all the respect he is due, I never have adjusted hot. I prefer not getting burned. They only change about .002" so that's not much. His way is the "correct" way, no question about it, but I just don't do it that way. It's personal preference.
