voltage regulator
Using the newer electronic that looks like the original. I have the blue mopar unit for 69 and earlier but like the look of the original style. I have not started it up yet but got my fingers crossed!!
What is the updated version and how should it be wired? I seen the diagrams but seems everyone that did it like that had problems
Looks like this only it has electronic guts instead of the old point contacts.
The newer mopar performance unit for 69 and earlier looks like this
Transpo c8313
I fried 3-4 of a lesser quality before going with this one. Adjustable voltage as well.
I keep hearing that. I think it's bull. But you can get the 'same" regulator from standard / Blue streak NAPA NAPA is VR1001, Blue Streak is VR128
Had one for over 20+ years on my dart with thousands of street miles
Same here and it has moved to mutliple cars with the electronic ignition set-up... The Blue unit works fine for the street...
Dan the irritant had a big rant on here one time about how they don't regulate because they are not grounded. I'm not sure I got the point. If that is REALLY all that is different with the "race only" units, then all you need to do is scrape the paint off for the bolts
After all a regulator that does not regulate is "hardly a regulator"
That IS the job of a "voltage regulator"-------to regulate voltage!!!! They have not changed lead acid batteries just because they are in a race car
You need a heavy duty one with the Hemi alternator. The field draw is up to 7 amps.
VR32 is the bottom line, and certainly not made if you need one for a heavy amp draw field
Which ever one you use make sure it is well grounded.
Bosch part number comes up with nothing is that the correct number? For some reason no one has any of these regulators locally and can not cross reference them with others.
The Bosch units used on Porsche, BMW, and Volvo I am familiar with have internal regulator that is part part of the module for the field brush assembly. It is easily changed out with a couple screws. Bosch units also need a warning indicator bulb energized by the ignition switch, for them to regulate.
true, I swapped always Bosch into my US cars. There are pretty small Nippon Denso's on the market as well. All with internal regulators.
I have a buddy in Auto parts supply here. Will search for an external Bosch regulator since i have this HEMI Alternator to use....
I got one like the original off ebay 5 years ago, its electronic no problems with it, also Im running a hundred amp alternator.
