Ok I have a guy that wants to do some trading on some stuff. Part of his stuff is a set of W2 iron heads that he says have never been run but have been stage 3 ported what ever that means.
A stage 3 porting is a bit un clear, I agree. To many places have stages that aren’t defined. Did they have a stage 5? Ridiculous! A flow sheet spec sheet would be awesome. Something he probably doesn’t have.
While I’m awake only 15 minutes, later don’t see any porting marks.
And off the cuff, unless your looking to make a real street monster, I’d stay with the Iron Ram heads.
With the current crop of cylinder heads on the market today, the prices of the W-2/5 should fall further making them an actual potential choice for some. Do your price checking and check your ultimate goals. There not to bad these days.
The casting # is 810. Being told these are full race heads by a buddy that’s has experience with W2’s. Gathering parts for a future small block build & not sure if I need this much head.
Always afford the best head you can afford.
More flow the merry.
What is the RPM range on these heads. Actually had budgeted in a pair of Iron Rams. But if I can trade for these ?
Heads do not have a RPM range. It is really the valve spring. And the cam profile. If you install a cam rated at 2k-6K or 4500 - 7500, what you need to start running the engine properly is the correct valve spring to handle the open and closing rates the cam needs. Controlling the valve is essential to RPM.
The heads ports are the next thing in line for rpm. If there to small, they’ll choke power on a big engine. But it will still turn 8k if the right spring is on top. This is not a problem with the W2.
What you are concerned about with the head is how much power can it make? This is the ability of the ports breathing. On a layman’s term, it is cfm X 2 = potential hp. This is very much a general term and under estimate math formula that excludes extreme hp racing combinations.
So what can a W2 flow?
Basic work (a loose term here) can provide 280-300 cfm. A professional that has skills and really intimate knowledge of the W-2 head can find around the area of 320+ cfm. So that potentially a small block with a terrific supporting cast like a great film can make 620 hp.
So what is the problem with a W2 head?
The problem is that most people will look at flow numbers alone and decide if the head is right for them and then finalize the deal when they penny pinch the associated costs to finish the job.
Flow wise, for a street head, the Iron Ram head is a great bang for the buck for the head alone in stock for and ported, it is really impressive that is goes up around and sometimes I have read to 300 cfm. It takes stock valve gear, no fancy extra parts like the shaft stands, off set rockers & can be purchased ready to run a bit cheaper than a W2.
If your doing a mello build, the Iron Ram’s are just fine. If your looking to make serious power, LOL, there actually still very good. If you go racing, you’ll want the edge. The IR’s now fall short and can not stand as tall as a W2.
The W2 has some really good things going for it though. Many people discount them and blow them off way to east.
An unrestricted port window.
The ability to to make a custom valve train set up that is really on target, not just OK or good. It’s a PIA to do, but it shows when your done.
People are still doing the older W2&5’s for a reason. The W heads are really good heads that require a little extra dollar to make a better head. You have to look at them as a puzzle that needs to be carved into what it can be.
Do comparative price shopping.
The W2 is not as expensive as it used to be. Remember they only come bare. So adding the valves is the extra cost. I discount the valve springs, retainers locks and valve seals because any serious or at least, a good build will require a change of valve springs. Retainers, locks and seals are pennies. Cheap chit. You’ll spend more on bubble gum.
I’m getting there with my W5’s.
(Ugh! Such a long and winding delayed road. Should have been done by now! That life I guess.)
It doesn’t have the Victor heads flow capacity but nor does it have the price tag that goes with the more expensive Victor head.
(And a big thanks to a few FABO member for the pictures below.)
Next up, my W2’s.
