W2 roller rockers
Discussion in 'Small Block Mopar Engine' started by abodyjim, Feb 6, 2017.
  1. abodyjim
    abodyjim Well-Known Member
    145
    77
    May 2, 2016
    Topeka Kansas
    Local Time:
    8:16 AM
    In the process of building a small block w2 stroker and would like to hear some opinions on roller rockers. Short block is 360/414 all forged with a solid mechanical cam. W2 heads are the econo version open chamber 2.08/1.6, 6500 rpm Street /race. So what I'd like to know is pros and cons between the t&d and jesel rockers.
  2. Dartthunder340
    Dartthunder340 Well-Known Member
    1,448
    1925
    Sep 13, 2010
    Colorado Springs,Co
    Local Time:
    8:16 AM
    Used Harlan Sharps on my w2's and love 'em. Sorry no experience with the other 2 brands. Would you consider H.S.?
  3. RustyRatRod
    RustyRatRod Just another dumbass. FABO Gold Member
    47,461
    12470
    Jun 7, 2010
    Georgia
    View My Photos
    Local Time:
    9:16 AM
    Norris
    • Like Like x 1
    • rumblefish360
      rumblefish360 so close yet so far away
      33,067
      5170
      Jun 21, 2005
      New York, on a Island
      View My Photos
      Local Time:
      9:16 AM
      And who is it that sells "Norris" rockers?
    • 70aarcuda
      70aarcuda Master Hoader of SBM FABO Gold Member
      13,950
      2035
      Jan 16, 2005
      las vegas
      View My Photos
      Local Time:
      6:16 AM
      I use crane, but they are not being made any more.
    • dodgedifferent2
      dodgedifferent2 Well-Known Member
      2,383
      234
      Aug 8, 2008
      southwestern, Ontario
      Local Time:
      8:16 AM
      Are they pushrod oiled (magnum) or la oiling?
      I have the la style oiling w2 and went with Harland sharp
    • abodyjim
      145
      77
      May 2, 2016
      Topeka Kansas
      Local Time:
      8:16 AM
      I considered the HS even though a friend had some bad luck with his but price wise they are the same as the t&d/jesel that's why I'm looking at these two.
    • abodyjim
      145
      77
      May 2, 2016
      Topeka Kansas
      Local Time:
      8:16 AM
      LA style, what made your choice?
    • abodyjim
      145
      77
      May 2, 2016
      Topeka Kansas
      Local Time:
      8:16 AM
      Rockers that are no longer available don't help me much. Don't know that I would even buy them used because of that.
    • 340duster
      340duster Well-Known Member
      1,066
      25
      Jun 3, 2004
      AB, Canada
      Local Time:
      7:16 AM
      Do jesel and t&D make w2 rockers for the econo heads? They do for the race w2 heads. Harland sharp does for sure make a set for the econo heads.
    • rumblefish360
      33,067
      5170
      Jun 21, 2005
      View My Photos
      Local Time:
      9:16 AM
      Head oiling style. He has the Econo W2's.
    • dodgedifferent2
      2,383
      234
      Aug 8, 2008
      Local Time:
      8:16 AM
      Mainly price.
      Everyone complained about price for all three though.
      Harland sharp seemed easier to get ahold of. The others seemed to give me the run around or didn't have them on the shelf ready to ship.
      Harland sharp made them and then shipped them out a week later after the order
    • abodyjim
      145
      77
      May 2, 2016
      Topeka Kansas
      Local Time:
      8:16 AM
      Hmmm, great question. When I called for a price I don't remember if I said econo or not
      Okay you had me second guessing myself because I didn't remember so I went back and checked, t&d does. Jesel does not, didn't catch that the first time I called. Also, jesel did not recommend them on a 59° block.
    • mbaird
      mbaird mbaird FABO Gold Member
      3,943
      1189
      Dec 10, 2005
      boise, Id
      Local Time:
      7:16 AM
      Not if he uses a magnum block.
      I have used Norris Stainless ( worked great) Now I am going with HS 20170131_193817.jpg
    • abodyjim
      145
      77
      May 2, 2016
      Topeka Kansas
      Local Time:
      8:16 AM
      I'm using an older 360 block not the magnum. Was your decision based on availability?
    • abodyjim
      145
      77
      May 2, 2016
      Topeka Kansas
      Local Time:
      8:16 AM
      Looks like my choice is HS or t&d
    • mbaird
      3,943
      1189
      Dec 10, 2005
      boise, Id
      Local Time:
      7:16 AM
      Norris is no longer made and I got a smokin deal on the Harlan Sharps due to the less than pretty finish on the exhaust rockers. They anodizing process was skipped. Besides I used them on a solid roller 440-6 with out a hitch for many years.
      I am building a near identical 408 and would be interested in the results for the rest of you guys.
      I am still up in the air on cam grind. I am looking for the sleeper effect so I want my idle to be somewhat close to normal...but my heads should flow 600+ so I want to take advantage of the flow.
      Any recommendations on cam profiles ?
      408 Forged Scat kit w/ 22cc dished icons
      65 cc race W2s Shady Dell Stage 2 and polished chambers 2.02
      Solid roller ?
      M1 Dual Plane port matched
      TTI Step headers
      4 sp
    • FredS
      FredS Well-Known Member
      877
      66
      Feb 13, 2013
      Arizona
      Local Time:
      7:16 AM
      T&Ds here. yeah they aren't cheap. Sleeper? what kind of power you want out of this motor?
      T&D shows a model for Econo W2s. 8100.
      • Thanks! Thanks! x 1
      • FredS
        877
        66
        Feb 13, 2013
        Arizona
        Local Time:
        7:16 AM
        why an M1 dual plane? stroker wont need that
      • rumblefish360
        33,067
        5170
        Jun 21, 2005
        View My Photos
        Local Time:
        9:16 AM
        Mbaird, what gears and tire size?
        Can I assume this is a street car build designed for fun and "Spirted Driving?" that needs to be street able and freindly with low to zero track time?
        FredS, the intake came with the heads. A dual plane will provide much more low end torque over the other available intakes which are all single plane intakes. MoPar is the only maker of a dual plane intake for a W2 head. Otherwise it is an expensive chore to modify a "LA" intake to fit.
        The MP - W2 - DP will flow very well. I do believe he is not strip bound.
      • abodyjim
        145
        77
        May 2, 2016
        Topeka Kansas
        Local Time:
        8:16 AM
        Our combos are close, I used the scat with icon flat tops.
        I called around about cams and everyone said I was picking too small of a cam. I was also looking at rollers and ended up going solid mechanical based on the information I got from Speier Racing head. The cam is a old Hughes grind made by engle. 256/265 @ .050 .587/.602
        That could change maybe due to the heads. They have been worked some, waiting to here back right now.
        I chose the Victor w2 after talking with Ryan at Shaddy Dell and plan on using the Tti headers as well.
        If I remember right Chad had it figured to make around 580hp
      • abodyjim
        145
        77
        May 2, 2016
        Topeka Kansas
        Local Time:
        8:16 AM
        580hp is what it worked out to on the computer. 6500 rpm max, and handle things like power tour and drag week type of events.
        Not much of a chance for a sleeper, narrowed rear and 3" Flowmasters
      • mbaird
        3,943
        1189
        Dec 10, 2005
        boise, Id
        Local Time:
        7:16 AM
        Dual plane for torque and stock appearance once painted. 3.55s and 26" tires ...but that all can be changed easily.
        Track maybe 2x a year...
        My guess is mid 500s HP.... This is going in a 4sp 69 Swinger with manual brakes and steering.
      • mbaird
        3,943
        1189
        Dec 10, 2005
        boise, Id
        Local Time:
        7:16 AM
        I dont mean sleeper that will fool a show judge... just a stock appearing car at a casual glance... anyone that knows engines will know right away .
      • abodyjim
        145
        77
        May 2, 2016
        Topeka Kansas
        Local Time:
        8:16 AM
        I think your numbers are on, have you started assembly yet?
