tarvin890
tarvin890
I can't wait to see what the cause is....
Agreed, he needs to call in sick and start taking the timing cover off..... WE are far more important than his job! LOLI can't wait to see what the cause is....
Same thought here....And I bet we have another on the forum right now with the same problem......
Looks like post 8, 13, and 19 NAILED it! Glad you found the issue......should run much better now!!!!
I lined up the dot on the key way, instead of the dot on the tooth. This put my piston almost an inch away from TDC, and I was 3 teeth off on my dot-to-dot alignment. I've never done that before, but hey, I own this one. I can't believe it ran, and didn't back fire or anything, just a SLUG.... lol. I will get this back as time permits, and I'm sure it will run as I expected. I will post the final results when she is back together.
Oh, here come the folks to chew me out for not using the degreeing wheel.....
If I may brag a little check out post 2
