What choose a reverse valve body?
My '69 Swinger 340 ended up with a RMVB 727 on the street and I loved it.
My current '69 Dart is going to have the same, except with a 200-4R with a lock-up converter.
With a RMVB if you put it in drive, and leave it there, will it still shift normally?
Or do you have to constantly shift gears up and down while driving around?
Wherever you put the lever, that's what gear it will stay in. If you leave it in "drive" (third) it will stay in third! You will be pulling away from a stop sign very slowly, and lugging the motor like mad. And if you shift into first at 75 mph, BAD things will happen.
You have to shift gears with a full manual valve body, just like a stick, but without the clutch.
