Thanks for the kind words all!
I would do it all over again........not
One of these is enough.
Great Thread Tony !
You have one the best looking 1967 barracuda i have ever seen !
Killer Ouside & Inside Color Combo !
Your list on restoration is right on if not a lilltle light on resto today !
When you spend more on a car than its worth .. you have to drive the difference out of it !
I fully understand your pride of your ride & in all it was worth getting exactly what you wanted !
Peace Brother !
Now make sure nobody's wife reads this post![]()
I'm with you here. I build entire houses for myself and don't even keep track. I want it to be what I want it to be, and keeping track isn't gonna change the bottom line one bit. It'll just use up more time, that I can never get back.I refuse to keep track of what I put in to my cars. It takes the fun out of it.
I've got 25k into my Demon....
well I paid someone else to do the work the first time and have since redone most of the mechanical systems myself so thanks for digging at that nerve Tony , I'm somewhere double your investment but try not to count so it could be even worse .
I look at it like this:
You can spend $40,000 on a brand new car, and have something like this:
And lose your car in the parking lot every time you walk out of some place....
OR
You can spend $40,000 on an older car and have something that's getting more and more rare to see on the roads, and turns heads wherever it goes!!
Pick your poison. ;)
Sorry for the old thread bump, but that's my philosophy on cars...
- CK
I must've gone about spending $$ on my GTX all wrong!!!...
First I bought a 72 Harley Sportster in pieces for $600, spent a few $$ on it buying missing parts at the swap meets. Then I traded it for a 64 Belvedere and spent a few $$ putting in a 440 and related drivetrain. Then I traded the Belve for the GTX, sold the 6pak setup that was on it and rebuilt the motor using the $$, and spent $400 to repaint it. Total investment so far...about $3500!!
Nowhere near as nice as your Cuda Tony, but I think I have some headroom for improvements!! Geof
I'm not sure this is the correct forum for this thread as I have already done
a restoration thread on my 'Cuda. What I wanted to share with you folks
is how we end up investing so much money into our cars.
There are several of you out there that think A bodies aren't worth very
much in our market today. That's probably the case as our A bodies were
never meant to bring high dollars even when new.
This thread is for you guys and gals thinking about doing a restoration on
your ride and have no idea what you might be in for. I realize you can
stop at anytime you want on your project but for the purpose of this
thread, lets not do that. Lets give this project everything it needs from
start to finish...within reason of course.
Lets get started...where's the calculator:sad7:
The initial investment and the type of car you start with if very important.
My initial investment was $2500.00. That sounded very reasonable to me
back in 2006 for a '67 'Cuda fastback. At that time I didn't realize the
differences between the slant 6 and the V8 drive train. My plan was to
build a V8 car when I bought it. Found out it wasn't wise to use small
drum brakes, small 7-1/4 rear end, small diameter torsion bars, anyway
you get the idea.
New disc brakes and spindles with large ball joints and upper control
arms added $1130.00. Used 340 torsion bars were $40.00 and a used
8-3/4 rear end was another $300.00. The cost of new Moser axles and
preparing the "C" body 8-3/4 was another $606.00. Add in another
$336.00 for a new ring and pinion and bearing set. Now tack on another
$100.00 for the gear set up. Starting to add up and we haven't even
started yet. I'm not trying to scare you, just telling you the facts from
my experience.
We will also need some wheels and tires. $50.00 for used steel 15" x 7" wheels
$290.00 to powder coat the wheels. Red line tires were another $985.16
Engine and tranny redo plus labor and the install was $8830.00. MSD stuff
was $554.00
Paint and body work added another $9000.00
The following is a list of stuff I had to buy for the 'Cuda because a lot of
this stuff was gone or in bad shape. Bear with me...
Radiator $384, fuel tank strap $37, front brake line kit $58, fan shroud
$192(junk re pop), fuel sending unit $159, spring shackle pkg. $70, leaf
springs $200, shift knob $25, flip fuel cap $120, deluxe screw kit $44,
glove box liner $22, roof rail weatherstrip $90, seat belts $100, front
fender patch $63, wheel lip molding screws $22, door panel clips $40,
seat buns $206, fuel tank $233, fish in a circle(2) $60, Chrysler star
emblem $13, ign/door lock kit $35, trunk lock kit $17, gas strap bolt $23,
center console $250, steering wheel $100, dog dish caps $71, radio $40
vents and cover $56, wiper knob $12, dash pad $78, bumper end brkts
$63, ash tray $37, fold down trunk panel $115, shift linkage $54, tie rod
ends/sleeves/brake parts $390, dash bezel/arm rest re chrome $677
fiberglass hood/scoop/hardware $760, window trim clips $47, window gaskets $179,
trunk mat $46, side glass weatherstrip $100, TTI exhaust system
$685, hose clamp kit $13, carpet $375, front glass $260, rear glass $790
tail light bezels $595, clips and misc screws $25, torsion bar support repair
parts $280, quarter panel skin $228, fuel and brake lines $128, tach $200
tach harness $30, remote mirror $277, trunk weather strip $39, fish
fender emblems $68, barracuda script $78, right tail light lens $132
p-l-y-m-o-u-t-h emblem $69, fuel tank pad $17, bumpers $760,
flex plate $111, seat covers $484, door panels $374, motor mounts $75,
redo drive shaft $160, trans brkt $41, emerg brake cable $95, drum brake
hardware $45, misc Year One gaskets, decals screws $57, control arm cam/shaft kit
$59, poly trans mount $40, door handles $195, window cranks $94, fender
splash shields $234, jack instructions $8, misc decals $35, antenna $174,
install headliner $150, wheel lip moldings $250, trunk trim $275, damper $100
pinion snubber $69, fan $33, mini starter $160, power coat dash frame
twice $300, hoses/clamps $298, back up lights $160
I probably have missed some stuff here but you get the jest of it when you
start with a car that needs everything like mine did. I started to use more used
stuff but the condition of it wasn't that good.
By using mostly new items I have created a car that I am very proud to
own and drive. It will never be sold (will be passed on to our daughter
Tonya and her husband Chris).
Our total investment is north of $38,700 and yes the car would never
bring that on the open market but that doesn't really bother me.
I hope this sheds some light on the restoration process and gives you
some data on what you might have ahead of you if you decide to take
the plunge. Good luck to you if you do.
Tony
You can view my restoration thread here:
http://www.forabodiesonly.com/mopar/showthread.php?t=16153&highlight=my+1967+cuda+restoration
