What is your fastest time to pull an engine, install another and drive it away?
I have done those swaps like above… cars nose to nose with enough room to rotate the hoist around.
Since I moved to this place, I’ve yet to do a fast swap.
My 2007 Truck is at 414,000 miles and I have a replacement engine here when needed. That will be a pull and swap deal when the time comes. No big effort to clean and detail the engine bay, just swap in the new heart and get it moving again.
I plan to do the swap maybe next weekend.
I’ve been getting stuff ready. I will be pulling the current 360 and saving it for my four door…
Because of that, I wanted to keep the engine as complete as I can. When it comes out, I’m considering leaving the exhaust manifolds in place along with the pulleys and alternator.
Yeah…. Mismatched valve covers! I have another pair like these hanging on the wall!
I thought of leaving the manifolds with the car and just reusing the whole exhaust system but I have headers and everything to make a good 2 1/2” setup so I may pull the whole exhaust setup here out to use in the 4 door.
I dug through the stash to find matching pulleys.
The setup on the Dart uses a cheapie 4 groove crank pulley. I used it years ago just because I had it. Belt alignment isn’t perfect but it has never thrown a belt.
The roller 360 will get a 2 groove crank pulley since I had one. I did have to use a 3/16” spacer to get the grooves to line up.
The outer groove is for power steering.
The radiator in the car is a single row 26” unit from a Chrysler Fifth Avenue.
I don’t recall ever having an overheating issue but I have another radiator I may use…
This 26” unit is a 3 core. I’ll need to get that upper hose nipple moved at a radiator shop.
That’s funny…….
Upper radiator hose opening dont matter what side its on just buy a new hose and run it over to the other side
I love stories like these from the old days.
No air tools, no cordless impacts, just wrenches and ratchets.
The 273 in the 64 Barracuda was put in by hand. In 1972 my buddy Irwin and I installed the shorblock by hand, then I built it up from there. Then I graduated to a chain fall, then a hoist. An impact was only used to take things apart, never to put things together, even to this day.
Well, yeah.....IF you can find a hose that is curved that way.
A big block hose should work if it clears the alternator and dipstick handle- the ID is the same as a small block.
For twelve bucks it may be worth a shot.
