fishy68
Tyr Fryr's Inc.
I use sonnax stuff at work alot.
My experience is that if you have a good valvebody a TF-2 kit works good.
If you have a worn out valvebody a TF-2 kit will make you pull your hair out!!
I have had good luck with both,more to building valvebodys than throwing in some springs and drilling holes sometimes.
I usually get the shift correction kit and build it to the customers preference,not everyone want's to leave there tire marks in second gear(even though it is fun![]()
Hey Rick. Maybe that's one reason I haven't had any issues with the Trans-go kits, because I haven't used any badly worn valve bodies. I have several good cores most of the time and can get them cheap any time I need one. I also build them to the customers liking. After all, their who we have to make happy.
