Badart
Senior Member
My zero deck 360 shortblock is getting finished up with KB 107s and have decided on a cam. It's a Comp XE-284H. Here are the cam specs.
240@50 on the intake
246@50 on the exhaust
.507 lift intake
.510 lift Exhaust
110 LSA
Hydraulic Flat Tappet Cam
I have already had my J heads rough cut for 2.02 valves has the smaller valve guides already installed and will taking them to the head porter in the next couple of weeks in Salt Lake and I need to give him some flow numbers to shoot for. (Yes I know that I should have gone with RHS heads, but I already have some money tied up in these and want to use them). I know stock J heads should flow around 220 from the factory, but what should I shoot for?
I am shooting for 10-1 compression ratio and this is a street car. The rest of the combo is Eddy air gap, 3K stall convertor, 3.89 gears (Furd 9") and running through hooker comp headers to 3" exhaust.
.507 lift intake
.510 lift Exhaust
110 LSA
