what spark plugs to run on my rhs heads
winstoninwisc
Taint easy livin free,season ticket ona 1wayride
sun prairie wi.
finally getting back to my engine now that it is above 30 degree"s ,its going in next week and I was wondering 2 things they are 2.02 rhs 360x heads bowled with a victor intake 525 lift with about 300 advertised duration .automatic.3:23 sure grip with a tsi tranny m.s.d. 6 al will be gapped at .045 on 97 0ctain pump fuel out of my 650 duel feed until I get my 750 . vac secondairys d/f holly any true support on spark plugs would be appreciated . 2nd do the tti headers trueley drop in a 65 barracuda with a small block or is there a lot of work to do yet. 4-6 weeks out how much HP would I loose using shorties? yes $ always a problem here only 2 1/2 years behind with this last cold *** winter ,it just didn't pay to heat the shop, solor heat on its way I hope thanks for any info on plugs sorry to all of you that have been on hold parts will be available soon for your 64/65 barracuda"s slow but sure thanks fabo
IMO Champion RC12YC heat range is TO hot for harder driving on the street. its cheaper to fowl a plug than burn holes in pistons. IMO.
NGK V-Power...GR5
You will love them. Its like adding more power. They really make a difference.
Shortie headers are not that bad unless you plan on drag racing, I have them and have no complaints.
You're going to get several answers but the NGK V-Power ZFR6E-11 (Later Magnum/Dakota R/T plug) is a good safe choice. They come pre-gapped at .045 btw.
You could try the NGK FR4 (spec'd for early Magnums) but I found them to be too hot.
I'm partial to NGKs (easier to read), but the Champion RC12YC (early OE plug) is also a good plug. The heat range is somewhere around the equivalent to an NGK #5 and comes pre-gapped at .036". You could also do the RC12LC4 (later OE plug), with the only difference being they're pre-gapped to .040".
