NormalPcGamer
Member
Hey, I'm looking for other people with a similar build as me so I can sorta gauge how the engine is running.
Car is a 1975 Plymouth Valiant
1978 LA 360 .030 over, flat top pistons, unknown compression ratio
U cast heads 2.02" int 1.60" exh
Comp XE268 cam specs
Edelbrock 750 carb #1407 set up to #9 on the Edelbrock calibration kit
Vac advance (ported vac source) distributor 19 deg at idle 38 total at about 2750
Hooker headers to dual exhaust
NGK RN14YC spark plugs
other things
3.23 suregrip in the 8 3/4
1973 904 transmission
25" tall tire
I don't know what I should be expecting out of this setup. I've owned this car for about 3 years (2 of that with the stock 318) but now I've swapped this engine in and its hard to tell if its actually running how it should be. I've never driven or really even been a passenger in any other car around this era (I'm only 21) and my other car couldn't be more of an opposite comparison (2013 Focus ST). My dad and I have been chipping away at everything that's been breaking on this car over the last 6 months or so but now its starting to run good enough where I can start fine tuning the carb and timing.
I'm trying to absorb as much information as I can so if you've got a similar set up, post as much information as you can, as in, carb size and jets/metering rod settings, timing, HP/TQ numbers, 1/4 mile times, videos of the car driving, tuning tips/tricks, anything I can use to compare my car with so I can get it running as best as I can.
Thanks!
other things
25" tall tire
Thanks!
