Hey guys, im building a 72/340 stock bottom end, installed a comp 268 cam with .477/.480 hydra cam. I ported the stock heads, exhaust and intake runners as well as some bowl and combustion cleaning. I have the 188 valves J heads. Nothing to wild,,just want to make the motor run it best for what I have. What do you recommend for intake manifold and a carb setup? I have a set of the HP manifolds I will be using, trying to stay away for headers. Cams power is between 1500 and 5500 rpms. Its an automatic car, with 3:23's. Some feedback would be appreciated..
