In my studies, I find the hydraulic rollers seem to have very long ramps to .050. To run a small .050 cam, requires a big advertised duration and usually, a lotta lift.
Here's an example; a
[email protected], might require a minimum 276 cam to perhaps a 282. And the lifts are gonna be well over .500,and closer to .600
Another somewhat difficult thing to work around is cylinder pressure. The stroker has a swept of 836cc.That's a lot. It's somewhat difficult to get the pressure down with a typical street cam in the 225 to 235 zone, to work with small chamber iron heads.
Aluminum heads make it much easier, cuz you can run an easy 20psi higher pressure,typically.
I'm thinking a better idea, if you have to have a roller, is a solid-roller.I have seen those with ramps down to 39* and less This makes that same 225,now a
[email protected]. Or the flipside is, you can run a 276-advertized/
[email protected], or about 2 sizes bigger.The penalty fort solids is periodic lash adjustments and a bit of tappet noise.
A lot of advertised duration is not necessarily a bad thing with iron heads tho, as you're gonna need to dump some pressure when running a small cam..
With an LA block, you don't run into that; the FTHs run about 40 to 46 * ramps.
The solids, I think I have seen 29* ramps.
All I'm saying is to get your ducks in a row, in the planning stages so you don't have an expensive-to-rectify situation later.
