perfacar
roll the motor again, both dots will line up, if cam dot is at 12 o clock, then your on #1 tdc. with dots at 6 o clock and 12 o clock, you're on # 6 tdc. the cam goes in on $ 6 tdc. then you roll it until the dots are 12 on cam gear and 12 on crank gear.So, apparently I messed up the install somewhere, dots don't line up. Going to start over finding TDC and cam centerline. Thanks for the advice. At least I believe there's hope for this engine!
