Which Shocks for SS Springs?
If you still have the 002 spring on the passenger's side, that's incorrect. Odd numbers on the passenger's side, even numbers on the driver's side.
They know.
Can also unbuckle the clamp on the driver side to help it load/bite that tire
Gabriel
Gab-81091
Extended 25.13”
Compressed 15.28”
Rusty, the Mopar Chassis manual says the 002 spring goes on the right side, 003 goes on the left side. So 002 goes on the passenger side, correct?
Summit, Mancini and "everybody else" says the opposite. I think that's right, too but I'll tell you how you can tell for sure. Look at the part numbers on your tail light lenses. Whichever is the even and odd is on the appropriate side. That's how they did everything that was side specific.
Pretty sure both side tail light lenses are the same on '72's like mine
Aight den. The tail light housings on Vixen are even number driver's side and odd number passenger's side. So yall are right. No doubt that everything else that's asymmetrical, such as leaf sprAngs.
Did you lower them? Mines raked pretty good with the SS springs
At one time I did have a 1 inch lowering block in there, but removed it for over-the-road clearance. The handling difference was slightly noticeable, but the added ground clearance for the road conditions these days was worth it.
You can use two of the driver's side springs if you prefer lower too. The tires pictured are 275/60-15's on an 8 inch rim. That's about as large as I can go without doing the inner fender wells.
I run the front at the stock ride height using 1.06" torsion bars, but did have to add tubular upper control arms and an adjustable lower strut rod to get more positive caster. The car is very stable and balanced set-up like this.
The CE C2730 shows an extended length of 23.62” , compressed 14.15”
The CE C2735 shows an extended length of 24.50” and compressed 14.5”
From what I’ve read we want something close to 25” extended, for SS leafs, correct?
I don't remember, i did my research a while back, for MY application.
68 fastback, s-60 rear end (i don't remember offhand axle housing diameter), tire size, 002/003 leafs on spring sliders and solid bushings.
Just remember if your going to drag race the car. Check the length by jacking up your car and let the leaf springs hang with your wheels on the car and shocks disconnected, to get the right length. The S/S srings need that to work right.
What shocks go with SS springs?
I read the threads, looked up the part numbers, got a brain anurism.
Anyone have the correct part# for a proper ss set up?
On my 68 Dart (002/003 springs) I used a set of rear shocks for like a mid 70s 3/4 ton Dodge van. It had the big eyelet top and bottom that I needed and they were long enough. Monroe 66859. Ideal for drag racing? Nope but they’re cheap and suit my needs. I originally bought kyb shocks that Mancini specifies for SS springs but the top eyelet is too small to fit over the upper mount stud..
