If you still have the 002 spring on the passenger's side, that's incorrect. Odd numbers on the passenger's side, even numbers on the driver's side.
Summit, Mancini and "everybody else" says the opposite. I think that's right, too but I'll tell you how you can tell for sure. Look at the part numbers on your tail light lenses. Whichever is the even and odd is on the appropriate side. That's how they did everything that was side specific.Rusty, the Mopar Chassis manual says the 002 spring goes on the right side, 003 goes on the left side. So 002 goes on the passenger side, correct?
Taller spring goes on the passenger side.Rusty, the Mopar Chassis manual says the 002 spring goes on the right side, 003 goes on the left side. So 002 goes on the passenger side, correct?
Agree.Taller spring goes on the passenger side.
What shocks go with SS springs?
I read the threads, looked up the part numbers, got a brain anurism.
Anyone have the correct part# for a proper ss set up?
24" Monroe Shocks went in... Shackles are Correct sitting on the ground.
SS Springs have settled down a bit, sits about 1/2" lower than it did 3yrs ago.
Rides just fine, Looks Great, Love it!
I Think that Pic of the Shackle being Forward was with the Car Jacked up with the Wheel removed...
Pretty sure both side tail light lenses are the same on '72's like mineSummit, Mancini and "everybody else" says the opposite. I think that's right, too but I'll tell you how you can tell for sure. Look at the part numbers on your tail light lenses. Whichever is the even and odd is on the appropriate side. That's how they did everything that was side specific.
Yeah those will probably be the same number. I was talking about those that are not symmetrical. I'll go look on Vixen. That'll answer it.
wait. wut?Aight den. The tail light housings on Vixen are even number driver's side and odd number driver's side.
Fixed it. LOLwait. wut?
I'm running two driver's side SS springs with single adjustable QA1's. I've tried Billsteins and Koni's and like the QA1's the best. I also have them on the front.Taller spring goes on the passenger side.
That's what I'm running for springs. The old Green Brick setupI'm running two driver's side SS springs with single adjustable QA1's. I've tried Billsteins and Koni's and like the QA1's the best. I also have them on the front.
Did you lower them? Mines raked pretty good with the SS springsI'm running two driver's side SS springs with single adjustable QA1's. I've tried Billsteins and Koni's and like the QA1's the best. I also have them on the front.
At one time I did have a 1 inch lowering block in there, but removed it for over-the-road clearance. The handling difference was slightly noticeable, but the added ground clearance for the road conditions these days was worth it.Did you lower them? Mines raked pretty good with the SS springs
The CE C2730 shows an extended length of 23.62” , compressed 14.15”
The CE C2735 shows an extended length of 24.50” and compressed 14.5”
From what I’ve read we want something close to 25” extended, for SS leafs, correct?
