6PakBee
That's a LOT of difference between plugs. You sure you don't have an intake manifold leak? I'm guessing you have headers, have you taken the header temps with a heat gun?
Have you fouled those plugs in the past? Sometimes they just won’t come back. That is too much spread for me. I would not live with it. I would recheck the condition of the ignition system. Wires etc. if it is dropping a cylinder out, you could chase your tail thinking it is distribution.
I believe you can data log. That would be able to align RPM, Trims, Oxygen, air and water temp, etc and see what is going on across the board during a drive.
How To Take A Data Log From Your Sniper EFI System
I'm pretty sure I don't have an intake manifold leak but I could be wrong. I did shoot the headers with a heat gun and there is a 70+- difference between the front (cylinders 1 & 2) and middle headers.That's a LOT of difference between plugs. You sure you don't have an intake manifold leak? I'm guessing you have headers, have you taken the header temps with a heat gun?
More sooty than wet. I'm going to pull all the plugs, photogaph them, and keep track of which cylinders they came out of so I can begin the process of figuring out how to tune the engine.Im no pro but what im seeing is too much timing and its rich. On the 2md and 3rd photos is the black on the plugs sooty or wet. Kinda looks like you have a leaky valve in those cylinders. If its sooty black its fuel deposits from being rich if its wet or gummy feeling its oil.
