1. wheelsport
    wheelsport Well-Known Member
    77
    39
    Jan 21, 2019
    Vancouver, Washington
    Local Time:
    12:00 AM
    The wipers on my '65 make a couple swipes and then stop for short time and does a couple more swipes. I bench ran the motor for 30 minutes with no problem. Does the s/w have Circuit breaker?
  2. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,143
    2818
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    3:00 AM
    I believe it does
  3. wheelsport
    77
    39
    Jan 21, 2019
    Local Time:
    12:00 AM
    Is the circuit breaker separate from the switch?
  4. 65 Dartman
    11,143
    2818
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    3:00 AM
    Like the headlight switch, it would be internal to the switch. Do you have the variable speed switch or something else?
  5. wheelsport
    77
    39
    Jan 21, 2019
    Local Time:
    12:00 AM
    I believe it is variable because there is one click and then no other clicks as its turns fully.
    • Agree Agree x 1
    • Treblig
      Treblig Well-Known Member
      5,927
      3150
      Oct 5, 2013
      South Texas
      Local Time:
      2:00 AM
      Maybe that particular wiper switch was made for a government car.........that is if it takes frequent breaks, but when you're watching it it works continuously ?????:rofl:
      • Like Like x 2
      • RedFish
        RedFish Well-Known Member
        24,042
        2700
        Sep 5, 2007
        Local Time:
        2:00 AM
        The circuit breaker is inside the switch and it is a strip of bimetal. It will crack in half and fail completely eventually. Learned that the hard way back in mid 80s.
        I took the 67 variable switch apart and routed those connections out of the switch so a common/can type cycling circuit breaker could be attached outboard. Of course the linkage and pivots were serviced to stop the high resistance in operation.
      • wheelsport
        77
        39
        Jan 21, 2019
        Local Time:
        12:00 AM
        Thanks for the idea. I lubed the linkage when I checked the motor a year ago. A strange thing happened yesterday when I tried the wipers. They kept working. Now how do you figure that?
        • Like Like x 1
        • RedFish
          24,042
          2700
          Sep 5, 2007
          Local Time:
          2:00 AM
          Change in the resistance? Water inside pivot(s) lubricating the rust/wear? Who knows?
        • Nigel Hely
          Nigel Hely 64DartDownUnder FABO Gold Member
          221
          98
          Sep 13, 2016
          Blue Mountains, Australia
          Local Time:
          5:00 PM
          Yeah, those pesky wipers know when they're being watched... LOL
