Hambony58
Anybody have opinions on which complete wiring harness I should buy for my 1970 Dodge dart? I am not on a tight budget but obviously don’t want to needlessly overpay. Thanks in advance. Hambony58
The year one underhood harness comes in two flavors.
One is the stock harness that works with all the original components.
One is a modified harness, possibly HU200AM for your 1970 dart. This harness may has three modifications:
1. It is wired for electronic ignition.
2. It is wired for an electronic voltage regulator (triangle connector)
3. It is wired for an isolated field alternator. This is the one with two field wires and one big wire for charging.
This was true on my 1968 cuda. I think in 1970 the stock harness already had the triangle connector regulator, and the isolated filed alternator. If that is the case on yours, then the only difference is the electronic ignition. You must still have the three wire alternator and the triangle connector regulator.
I am not sure about your blue regulator. CAn you post a picture?
Contact YO or M&H because the photos with each of those are the same. get a real pic and description.Just to clairify, my Dart is a 1969, which may be what's causing me issues with finding a direct plug and play with everything correct.
So, did a little more digging and reading. The harness I was looking at was the HU201AM (1966-74 A B E-Body Engine Forward Light Harness). After reading the note on the bottom of the page it appears this harness, which is set up for electronic ignition and electronic voltage regulator, is for the 'newer' style voltage regulator (triangle connection, 1970+). My regulator is the 1969 and earlier style (http://www.brewersperformance.com/prodimages/large/P3690732.jpg).
My second issue would be that my alternator is also the older style, single wire alternator (round style as opposed to the squareback style).
Looks to me like I'll either have to get the YearOne points ignition harness and modify it, or get this one and switch my voltage regulator to the newer style, as well as my alternator.
I believe that, even though more expensive, Evan's would probably make me a harness for the voltage regulator and alternator that I have, instead of me switching things or having to change wire runs and ends.
Not quite following you here.I had a newer alternator, so I was able to swap grounded brush from ground to a spade lug to make the conversion to a two wire field. I guess the best solution depends on just what you want to end up with. Having a new alternator and regulator is not a bad thing though.
